Latest post 01-31-2011 12:28 PM by Keith Saunders. 6 replies.
Page 1 of 1 (7 items)
  • 01-29-2011 7:54 AM
    Loading configuration failed - Please charge the Beo6
    Just parchased a Beo 6 but I can't get it to work. I work with a 64Bit Windows 7. I have tried the new software under XP mode but I can't download it on the the Beo 6.
    It can't be the programming because when I just add a zone with one BV it still won't download on to the Beo 6
    I have checked the beo 6 is fully charged.
    Loading configuration failed - Please charge the Beo6 for 15 minutes, restart the Configuration Tool and try again !
    Anyone?
    Thanks, Chucky
    Wanna play?!! (Also a PRIZEWINNER ON BEOWORLD!)
  • 01-29-2011 8:43 AM In reply to
    Re: Loading configuration failed - Please charge the Beo6
    Hi,  I always backup my existing Beo5 configuration file (using the export feature on the tool) then remove the old Config Tool in Windows, delete the B&O folder and sub folders from my c:\, then install the latest Config Tool before importing the my existing Beo5 configuration file.  Doing things this way I've never encountered any difficulties.
  • 01-29-2011 9:23 AM In reply to
    Beo5 configuration program does not work on Win 64 bit computer.
    My Bang & Olufsen....
    • BeoCenter 2 DAB/DVD mk.II
    • BeoVision 7-40 DVD mk.III
    • BeoLab Penta mk.III
    • BeoLab 4000 icepower
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beo 4 mk.I & mk.III
    • Beocom 6000
    • A8 Earphones
  • 01-29-2011 10:20 AM In reply to
    64 Bit in XP Mode. It does not work on my other computer as well, an XP Machine.
    Same error..
  • 01-29-2011 3:28 PM In reply to
    Do you use 3.87 or 4.11
    The first won't work. I did get similar errors
  • 01-30-2011 5:11 AM In reply to
    • adro
    • Not Ranked
    • Joined on 08-26-2009
    • Posts 23
    • Gold Member
    Correct 3.87 will not work with Beo6, you need 4.11
    4.11 is 32 bit only.
    You may need to load/install the usb drivers manuelly:
      C:\Bang & Olufsen\Beo5 Configuration Tool\Beo5Driver\Beo5Usb.inf
    Adro
  • 01-31-2011 12:28 PM In reply to
    chucky:
    As others have stated you cannot use the Beo5/Beo6 Configuration Tool on a 64 bit machine.
    The Beo6 uses different firmware loaded into it and ONLY version 4.11 comes with this firmware Version 1.0
    With the Beo6 on to the base and the USB cable connected to your PC, in the download section of the Configuration Tool, if the "Download" button is NOT greyed out, then your problem is NOT the USB driver.
    Assuming the "Download" button is NOT greyed out, then the most likely cause of the "Loading Configuration Failed" error will be problem in your configuration.xml file.
    To prove the point, save your "Configuration.XML" and/or create a new configuration with a dummy serial number with something very basic in the configuration and download again. If it works, then you know the problem is with your configuration file.
    Regards Keith....
