Hi
Does anybody know an external electric socket which works with the Beo4 or Beo5.
I would like to start an electric device by pressing a button. Like a LC2 but without the dimm function. Does anybody know something like that?
You can use an LC2 as a switch without dimming function.
Thanks Stefan.
But my Onkyo receiver needs 830 Watt. :-( So I need something else than LC2.
Ok. So maybe this will help:
http://www.lintronic.dk/Relay-208.htm
BTW: Are you sure your receiver needs 830 Watt...??
Stefan
Sorry I meant my Panasonic Plasma which needs 450 watt.
You can solve this with a Light Manager Pro B&O sersion from jbmedia in Germany and high power actuators:
Lightmanager Pro B&O
http://cms.jbmedia.de/index.php?option=com_content&task=view&id=95&Itemid=74
Lightmanager Pro B&O shop
http://cms.jbmedia.de/index.php?option=com_wrapper&Itemid=8&lang=en
Actuators (2nd is high power Version with up to 3500 Watt max) http://cms.jbmedia.de/index.php?option=com_wrapper&Itemid=8&lang=en easy programming on a Windows PC and very good service
