1st March February 2012
01-24-2011 4:17 PM
Henry
- Joined on 11-30-2010
- London
- Posts 17
The Beosound 8 is a wonderful iPod/iPad dock but regrettably is totally dumb and reliant on a decent app on the iDevice that you use. The Beoplayer app is totally useless having so few UK radio stations. Any one country gets no more than three or four stations as there are only 20. How much does it cost, or how difficult can it be to add a wide range of stations but there is still no upgraded version available?
I've not found, despite purchasing a good few, a radio app that will allow me to go to sleep on a timer playing music from the iPod player and then wake up to a radio station set with the alarm function. It just doesn't work.
Does anyone know of an app that can do this?
redfresnel
- Joined on 12-25-2007
- Tampere, Finland
- Posts 94
This may be off-topic but don't you need earphones connected to the iDevice to be used as an antenna for receiving (wider range of) stations? Or is there something on BS8 that is used for radio reception?
redfresnel
- Tampere, Finland
- Posts 94
Sorry, my bad. :) Since the word "internet" was not associated with radio stations earlier i thought he was talking about normal radio reception which can also be done with iPods etc. :)
Sorry guys.
jc
- Joined on 11-06-2007
- The Netherlands
- Posts 145
Isn't internet-radio-listening by an iPhone limited by the "fair use policy" of your telecom provider?
And listening radio wit an iPod is not possible at all, or am I missing something?
soundproof
- Joined on 04-16-2007
- Posts 2,340
An iPod Touch, iPhone or iPad can be used with ease for radio reception - preferably using WiFi, or 3G on the latter two. You need an app which receives radio, and there are lots in the app-store.
I have one which I use to either listen directly on the iDevice, or to send it to any of my sound systems via AirPlay, using my home network. The B&O app is suppsed to get thousands of netradio stations.
Check out Tunemark Radio for a sample app. Or Accuradio.
Get an app that doesn't give you advertising, and you're set (unless you love advertising.) There are lots of country-specific apps - my national broadcaster has their own, and it has AirPlay, which means I can pick any of their stations and send it to my systems. If you have Airport Express connected to the BeoSound 8 you can do the same.
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
jc:
There's no frequency tuned radio in the iPhone, iPad or iPod , that's right, only internet radio. I guess there's radio add-ons available...? Not sure if they will work with a dock though.
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
redfresnel
- Tampere, Finland
- Posts 94
bayerische:
jc:
5th gen iPods and iPod Nanos with SW ver. 1.1. have FM tuner. Again this is off the original topic ( ) and this radio cannot be used with BS8 but i think this is what you meant with frequency tuned radio?
bayerische
- Helsinki, Finland
- Posts 3,593
redfresnel:
bayerische:
jc:
Just saw that, wasn't aware! Are you sure the iPod classic I presume you mean has FM? I saw it only mentioned on the Nano...?
-Andreas
soundproof
- Posts 2,340
You can place your iPhone/iPad/iPod Touch in the dock on the BeoSound 8, and use WiFi to access a service such as that of AccuRadio. And then you are streaming content to the speakers.
redfresnel
- Tampere, Finland
- Posts 94
bayerische:
redfresnel:
bayerische:
jc:
Hmmm...Maybe i misunderstood something from the Apple site and maybe then the FM tuner for other models is only with the external Radio Remote, not sure...Atleast on Nano it's integrated, that i physically confirmed this morning.
Chrisreunion
- Joined on 07-01-2007
- Reunion Island
- Posts 677
For me, one of the major weaknesses of the BeoPlayer app for Idevices is that , as for all other B&O-based softwares, it doesn't show any information about track, artist and album names, unlike the free BMLink with BeoPort or even the almost-free Linkplayer.. So I don't think I will purchase the new app, even if it has a wide choice of stations.
Reunion Island is greeting you!
Karel Uyttendaele
- Joined on 05-19-2007
- Aalst, Belgium
- Posts 682
If my memory serves me right.. then the App is intended for tuning into radio stations and the clock functions... nothing more.
If you want to see track/artist/album name.. then just use the iPod function on your iPhone when it's docked into the BeoSound 8! Why would B&O re-invent the wheel if there's already a way of displaying all the info? And.. it's controllable with the remote.
The race for quality has no finish line- so technically, it's more like a death march.
beopaul
- Joined on 07-28-2007
- USA
- Posts 68
No, Chris is right. These internet radio stations broadcast song infomation that iTunes and other software can display. I too find the lack of this info in the BeoPlayer app annoying. B&O could certainly add this via an update however.
Karel Uyttendaele
- Aalst, Belgium
- Posts 682
BeoPaul... why would you add an music player interface in BeoPlayer when you have an iPod function in very iPhone/iPod Touch? If you want to play your music files start the iPod. Want to listen to the radio? Start the BeoPlayer.
Both can be controlled with the remote. So I don't see the problem.
Let's be honest.. If B&O would add such an option in the BeoPlayer app then everyone would argue that this function already exists on their iPhone/iPod Touch... and that B&O did a lousy job implementing it.
beopaul
- USA
- Posts 68
Karel, I'm not saying add a music player interface. That would indeed be silly. I, and presumably Chris, are talking about music information shown for streaming internet radio music. When I listen to Absolute Radio on my computer through iTunes, it shows the song title, album and artist, which is really helpful if it's something I haven't heard before. On the other hand, when playing this through BeoPlayer on my iPhone, I get none of this data. Many internet radio stations include this info in the data stream, and as you can see from the AccuRadio screen snap earlier in this thread, this feature is present in other apps.
The Plumber
- Plymouth UK
- Posts 669
Henry:The Beosound 8 is a wonderful iPod/iPad dock but regrettably is totally dumb and reliant on a decent app on the iDevice that you use. The Beoplayer app is totally useless having so few UK radio stations. Any one country gets no more than three or four stations as there are only 20. How much does it cost, or how difficult can it be to add a wide range of stations but there is still no upgraded version available?
Here you go Henry, try this app http://www.tunein-radio.com/index.html
Never Mind The Ball-Cocks
www.markmossplumbing.co.uk
A labourer uses his hands A tradesman uses his hands and his head A craftsman uses his hands, his head and his heart
Raeuber
- Joined on 12-02-2007
- Posts 986
Or search for Radio.fx in Apple's App Store. /Räuber
