Latest post 01-27-2011 2:44 PM by stotty1111. 3 replies.
Page 1 of 1 (4 items)
  • 01-24-2011 7:12 AM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    BC9300 Tape deck
    Mr Stupid hereConfused,
    Just replaced the belts on this deck, all works fine apart from the head positioning system  -  the unit picks up the tape etc then sounds like sound thro cotton wool, gently moving the head rotational to the limit of its travel, then it works fine, the system does not seem to rotate the head far enough in either direction!
    Any helpful suggestions out there apart from the obvious, wear boxing gloves and get a pro to sort it!!
    salut
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 01-26-2011 3:10 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: BC9300 Tape deck
    Ok so no suggestions
    Is it kaputt?
    Can it be repaired?
    Anyone out there who repairs these ?
    Anyone got a suitable replacement unit?
    salut
    Tony
  • 01-26-2011 3:59 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Sounds as if the tapehead does not rotate fully to it's correct positions.
    Check if something is blocking or binding the rotation and/or if something
    has been bent or similar when you replaced the belts.
  • 01-27-2011 2:44 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Thanks Martin
    Hope to get to it tomorrow or over the qweekend
    Salut
    tony
