Latest post 01-25-2011 10:01 PM by Jonathan. 5 replies.
Page 1 of 1 (6 items)
  • 01-24-2011 1:17 AM
    DVD Mechanism
    Hi Beoworlders,
    Can anyone tell me if the DVD mechs on a Beocenter 1 are the same as the DVD1 mechs? I have a Beocenter 1 with a faulty DVD player and a perfectly good working DVD 1 that I could hopefully transplant to make the Beocenter 1 as good as new!
    Any advice would be invaluable.
    My B&O: 2009 Catalogue and Pricelist
  • 01-24-2011 5:05 PM In reply to
    Re: DVD Mechanism
    Anyone??
    or am I just asking a blatantly obvious question?
    I'd just prefer to know for sure.....
  • 01-24-2011 5:28 PM In reply to
    Re: DVD Mechanism
    They both vary! Both use either a Philips or a Pioneer mechanism. What is the betting you have one of each!! Whether they are just plug and play is another matter all together!
  • 01-24-2011 5:53 PM In reply to
    Re: DVD Mechanism
    haha knowing my luck...
    is it easy to spot the difference? or is it by type number?
  • 01-25-2011 1:40 PM In reply to
    Re: DVD Mechanism
    I have a spare DVD mech from a later BC1.
    Not been able to test it though.........
    Any good?
    Train Hard - Run Fast - Hit to Kill!!!
  • 01-25-2011 10:01 PM In reply to
    Re: DVD Mechanism
    I'll get back to you in a week or so.. The TV is on its way to me Erm
