1st March February 2012
Latest post 07-06-2007 4:40 PM by Hagen2000. 38 replies.
soundproof
- Joined on 04-16-2007
- Posts 2,340
Re: Cables that make a difference
Puncher: philipsmz333: Puncher: Addendum - In my earlier post I forgot to mention mains cords - I do find that a reasonable mains cord brings my system to life whereas, without, it just seems lifeless.
Maybe... just maybe, it's all an illusion
I
can see I didn't stick my toungue far enough into my cheek - its
definitely not an illusion, without a mains cord my system is entirely lifeless!
Cheeky!    And have you noticed how your sound system just doesn't get going without air? (I better be careful. Soon audiophiles could be buying special air mixtures for optimal propagation of soundwaves adjusted to the frequency range).
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
Yes very cheeky! lol
soundproof
- Posts 2,340
ChrDH:Looks interesting! Which one of the cables would I be needing to connect my Ouverture (Powerlink) to my Rega amp (RCA), bearing in mind that using a normal Din-RCA converter I have to use the 'Line In' cords on the Rca part to get the sound from the Powerlink? (The 'line in' pins on a Din connector is the 'line out' pins in a Powerlink cable). best regards Chr.
Hi Christian, I don't have experience with doing what you require here. I have, however, piped sound out from the Powerlink connector through a regular RCA>DINconverter.
I wonder whether what Bulgarien has done here wouldn't be of assistance to you:
 See his thread on the General Forum concerning ICE-power for the masses!
ChrDH
- Denmark
- Posts 493
soundproof: ChrDH: Looks interesting! Which one of the cables would I be needing to connect my Ouverture (Powerlink) to my Rega amp (RCA), bearing in mind that using a normal Din-RCA converter I have to use the 'Line In' cords on the Rca part to get the sound from the Powerlink? (The 'line in' pins on a Din connector is the 'line out' pins in a Powerlink cable). best regards Chr.
Hi I use a regular Din>RCA converter at the moment, just like Bulgarien is dooing. I just thought that the converter cables mentioned in this thread is probably better quality than what I am using at the moment. I should probably get a full Din>RCA converter cable, then I am sure that is will work. Thanks Best regards Christian
Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
Hagen2000
- Joined on 05-08-2007
- Munich
- Posts 267
Nice thread so far...
I would like to know if there are high quality DIN connectors available - to replace the connectors on my powerlink cables as well as the females in my BL8000s. The problem is that the B&O connectors (just my personal opinion) are low (consumer) quality and I experience from time to time hum and other problems due to the connectors being oxidized. I have to unplug and replug them several times to get rid of that hum (propably an earthing problem) and retain the full audio quality.
I even thought about of removing all connectors and soldering all cables directly but this seems to be an extreme solution which is quite inflexible.
Anybody else experienced these problems?
soundproof
- Posts 2,340
Bulgarien:Try to look at thees treads Its shows with lot of pictures and detail all kind of DIN/phono/jack etc. plug connektion to B&O. Its all made by Peter Pan, a helpfull and great B&O writer from Denmark, not by me
Clearly, what Peter Pan doesn't know about cables isn't worth knowing! I see he too links to Flashback Sales for the interconnects, that's reassuring. I think it would be mad to go for the expensive NAIM cables - the nickel connectors from Flashback are superb; as are the ones with gold plating. (Nickel actually more expensive). I agree with Hagen about the quality of many of the B&O plugs - they feel brittle and off-benchmark. Some of the cables shown by Peter Pan are of that category -- Flashback's work is leagues above in quality. (Hmmm - I should get a cut from Dave, I think!)
Chris
- Bredene near Ostend-Belgium
- Posts 143
Hagen2000:Nice thread so far...
You could give a try at NEUTRIK, they have gold plated din connectors. But it will be difficult to get them, most shops don't sell DIN connectors anymore, its a outdated connector from the '70. Here is a link, but I guess they have more types than this :
http://www.neutrik.com/content/products/level03.aspx?id=204_18467&catId=CatMSDE_audio
Yes, I kown my spelling is horrible…
soundproof
- Posts 2,340
Chris:You could give a try at NEUTRIK, they have gold plated din connectors. But it will be difficult to get them, most shops don't sell DIN connectors anymore, its a outdated connector from the '70.
Well, don't tell NAIM that. You're right in that DIN connectors aren't used as much by other manufacturers, but NAIM swears by them still, and many swear by NAIM. http://www.naim-audio.com/products/cables.html
Beolab
- Joined on 05-18-2007
- Sweden
- Posts 535
soundproof: Chris: You could give a try at NEUTRIK, they have gold plated din connectors. But it will be difficult to get them, most shops don't sell DIN connectors anymore, its a outdated connector from the '70.
Does Naim 5 pol cable work and fit with B&O???? Regards
soundproof
- Posts 2,340
Beolab:Does Naim 5 pol cable work and fit with B&O???? Regards
I haven't used the specific NAIM cables, but the ones I bought from Flashback are intended for NAIM/QUAD equipment, and fitted my Beomaster 7000 and Beolab 5000 perfectly. I'm using RCA PHONO male>5-pin DIN plugs from one DAC to the Beomaster 7000 AUX; and a 5-pin DIN>RCA PHONO female connector to have handy (that had to be connected to TAPE on the Beolab 5000, as the TAPE and AUX active pins are different on that unit). I'll be looking to get an XLR>5-pin DIN cable next, as my other DAC is supposed to have its best output from the XLR connectors. Perfect fit, good quality cable, good price. Flashback also have a 5-pin DIN>Minijack built to the same standards, good for iPods, etc., yet you'll also find those at Lifestyle (from Bosscom).
Chris
- Posts 143
soundproof: Chris:You could give a try at NEUTRIK, they have gold plated din connectors. But it will be difficult to get them, most shops don't sell DIN connectors anymore, its a outdated connector from the '70.
I was not comparing the air-PLUG connector with the normal din-plug. There is no comparison between both, the air-PLUG has Hi-End build quality and most interesting as I quote: " a design to reduce
eddy current effects and a cable clamping mechanism that doesn’t
squash the cable and affect the impedance". A normal din-plug is missing this great quality.
Hagen2000
- Munich
- Posts 267
Chris:You could give a try at NEUTRIK, they have gold plated din connectors. But it will be difficult to get them, most shops don't sell DIN connectors anymore, its a outdated connector from the '70. Here is a link, but I guess they have more types than this :
Hi Chris,
thanks for the link - they appear to be better quality than the standard stuff available in electronic shops. But I still miss females that can be mounted on printed circuit boards - I think I would need them if I should really go to replace the females in my BL8000s (these seem to be the worst ones).
