Thanks,
This PUC is far better than the one I use today, but...
... My dealer is 150 km away and the integration of this PUC in my TVs could be rather expensive as it can only be done at my home (BV9 !!).
That's why I am looking for an XML file, in order to control the Tvix directly from Beo5.
Any help would be very appreciated!
Kind regards,
Yann.
Ne pas s'en faire et boire frais!
Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
