Latest post 01-22-2011 5:08 PM by tournedos. 5 replies.
Page 1 of 1 (6 items)
  • 01-22-2011 2:35 PM
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    A Tape 2
    Hi there I am happily listening to ATape2 on my beocenter 9300 but what is the command from a newer Beo4 with DTV? I tried NMusic and that gave me the radio i think. Any Ideas?
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 01-22-2011 2:47 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: A Tape 2
    CraigSmile
  • 01-22-2011 2:51 PM In reply to
    • Craig
    • Posts 4,855
    Re: A Tape 2
    Try N.Radio then. It's one or the other.
    CraigSmile
  • 01-22-2011 3:01 PM In reply to
    Re: A Tape 2
    No.. N.MUSIC is the same as A.TAPE2, N.RADIO is the same as PHONO.
    p.
  • 01-22-2011 4:48 PM In reply to
    Re: A Tape 2
    PhilLondon:
    p.
    ... but in fact on a 9300, the Phone and Tape2 inputs come in on the same connector. On mine, I have airport express connected to that input, and I get the music whether I select Phono or Tape2 on the unit. So I set my Beo4 list to have only N.Music as a choice and I use that. On my Beolink 1000 it's shift-A.Tape.
    Looking at my Lintronic code table, these IR codes are equivalent:
    Phono, N.Radio
    Shift-A.Tape, A Tape 2, N.Music
    (I'm curious how this works out on a 9500, which had the RIAA preamp built in, so maybe on a 9500 you could have 3 items plugged in, say a TV, a second tape, and a phono? On a 9300 you can really only have two things plugged in, and the phono had to have it's own preamp or use a little amp box.)
    Steve
  • 01-22-2011 5:08 PM In reply to
    Re: A Tape 2
    spthomas:
    Exactly - it has three separate physical inputs. As do all the older models, it was only the 9300 that was scaled down in this respect.
    -mika
