Latest post 01-25-2011 4:37 PM by Dillen. 10 replies.
Page 1 of 1 (11 items)
  • 01-21-2011 2:37 PM
    Beomaster 2400-2 Bulb change
    I have a bulb gone on FM1 and i don't know how to open the case up to change it. Any help would be fantastic
    thanks steve
  • 01-21-2011 4:06 PM In reply to
    Re: Beomaster 2400-2 Bulb change
    You might want to replace all the bulbs. they are 15v 1 w. leaded style so you will have to solder new ones in and desolder the old ones out.
    There are kits available with instructions on how to do it. Not really a hard job.
  • 01-21-2011 8:45 PM In reply to
    As Eugene says, its easy, in the manuel on site there is a good description on how to open the magic box, desolder and solder the lamps is easy, and change all of them, new ones are brighter than the old ones.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 01-22-2011 2:38 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Welcome to Beoworld !
    I can supply a lamp kit for the Beomaster 1900 and 2400 models.
    It contains a full set of fresh panel lamps (plus a spare) of correct
    type and wattage, which is important in this Beomaster since most
    of the lamps work as vital parts of the electronic circuitry.
    The kit comes with detailed (dis-)assembly instructions (english text and photos).
    Basic electronic tools (soldering) is required to replace the bulbs.
    I agree with Søren in changing them all in one go. It will bring equal
    light output to the panel and since the lamps filaments becomes brittle
    with age and use, more of the lamps will unavoidably go bad from
    service vibrations.
  • 01-23-2011 10:41 AM In reply to
    How do I purchase these?
  • 01-23-2011 10:50 AM In reply to
    • Dillen
    • Posts 5,008
    kevineads, you have a PM regarding the lamp kit.
    Check your inbox inthe top right corner of this webpage.
  • 01-23-2011 11:51 AM In reply to
    I would also replace all 15 lamps. It is not the first time that someone replaced just the defective lamps to find out that after the BeoMaster was put together again another lamp is broken. R Simply replace all of them and have fun mounting the front of the BeoMaster after the repair....Wink Maybe you should also have a look at the capacitors, they also might need replacing and since you already have to disassemble the BeoMaster to change the bulbs. Dillen can probably also supply a capacitor kit!
  • 01-25-2011 8:51 AM In reply to
    Hi Martin, can you tell me cost etc and how to pay you for the kit.
    Kindest regards
    Steve
  • 01-25-2011 10:09 AM In reply to
    • Dillen
    • Posts 5,008
    Sure, PM to you !
  • 01-25-2011 4:01 PM In reply to
    Is there a lamp kit available for a Beomaster 1900. Looks like mine could be brighter, not sure though!
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 01-25-2011 4:37 PM In reply to
    • Dillen
    • Posts 5,008
    Yes, a kit exists. You have a PM too.
