I need to find out if the Beocord 1500 DeLuxe cabinet is the same size as the Beocord 2000 DeLuxe K. The 1500 DeLuxe has turned up close to me and I have been looking for the 2000 to fit in my console Beomaster 1200 RG.
Guy
I have had them both and I'm quite sure their cabinets are the same size.
Thanks Martin...
...then I guess I'll go and check out this reel to reel. He does say that the reels turn slowly. Are belts still available for this model?
I don't have them. - At least not yet.
Slow running could also be a result of dried lubrication.You will have to look inside.
