Latest post 01-20-2011 8:27 AM by vikinger. 2 replies.
Page 1 of 1 (3 items)
  • 01-19-2011 3:29 PM
    Beovision 5: interior screen cleaning?
    When I look very closely at the screen of my BV5 with it turned off I can see some cloudy smudges, possibly inside the front screen glass. I guess they've accumulated over many years use and the smudges don't interfere at all with the picture. However, if I wanted to clean the back of the front glass is this possible and straight forward?
    (I think it's probably best left alone but just thought I'd pose the question in the hope that someone said it was a 5 min job!)
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 01-20-2011 4:56 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: Beovision 5: interior screen cleaning?
    Hi Graham
    It's a two man job and absolutely NOT a 5 minute job. The plasma screen has to be removed form the cabinet to enable you to remove the screen from the front of the panel.
    Leave well alone until you absolutely have to have it looked at.
    Opman
  • 01-20-2011 8:27 AM In reply to
    Thanks Nick.
    I will be leaving well alone!
    Graham
