Latest post 01-21-2011 6:19 AM by BenSA. 9 replies.
Page 1 of 1 (10 items)
  • 01-19-2011 12:55 PM
    • BenSA
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Durban, South Africa
    • Posts 808
    • Gold Member
    BM 6000 Quad tuning string!
    The tuning string on my Bm 6000 Quad snapped. I opened the Bm but am unable to find how the string goes......it must the most complicated string system I have ever seen! I've been battling for over an hour with no luck. Seriously, was it necessary to make it so complicated!! Driving me insane....so is anyone able to tell me how the string goes back?? Otherwise I'm going to put all back together and not use the big dial which is a pity but I will go insane if I spend another minute on it!!
    Durban South Africa
  • 01-19-2011 1:19 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: BM 6000 Quad tuning string!
    Not the easiest task, for sure.
    Patience, strong coffee and page 6-2 in the service manual are key words.
  • 01-19-2011 2:30 PM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    Dillen:
    I was afraid that would be the answer lol!!!
    Durban South Africa
  • 01-20-2011 5:16 AM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    BenSA:
    Dillen:
    Well I've upgraded to silver to get the manuals :)
    Durban South Africa
  • 01-20-2011 5:36 AM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    Still looks ridiculously complicated even with diagram but will give it a bash when i get home!
    Durban South Africa
  • 01-20-2011 7:18 AM In reply to
    • Dillen
    • Posts 5,008
    Thanks, your support is greatly appreciated !
    I remember doing one of these a couple of years ago and I had it all put nicely together
    only to find out I had the tuning wheel rotating in the wrong direction.
    Direction of string travel is worth noting as the first thing.
    Then, when you have the path worked out, work in small steps, using
    pieces of masking tape or similar to hold the string in position in strategic places.
    The manual will tell you to fit the spring (tension) as the last thing but I've found
    that to be very difficult at times. I like to mount the whole thing, also the spring with its
    tied knots, before adding tension, actually I often start with the spring because it provides a good hold of
    the end of the string. I then choose one or two of the smaller dial wheels and deliberately feed
    the string below the wheels, so that it runs on the brass stand or spindle. Then, when the
    whole thing is ready and set, I lift the string up to the wheels, helping the spring a little with
    a small screwdriver or similar to allow it to shed some string length from the capacitor pulley.
    Using this trick on one, two or sometimes three little wheels will add the tension needed.
  • 01-20-2011 3:34 PM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    Thanks for the tips Martin. One more problem I'm afraid!!
    The Tuning string has obviously gotten old and when I tried to thread it back it kept breaking, so now I have a whole lot of broken pieces of string!! I'm not sure what the best subsitute would but I guess I could find something. Only problem is how long should the string be?? Does it matter if its a bit shorter or longer?
    Thanks Ben
    Durban South Africa
  • 01-20-2011 3:44 PM In reply to
    • Dillen
    • Posts 5,008
    I've seen many different substitutes, fishing line etc. but there's really
    nothing like working with real dial string.
    It's still available from many suppliers and it's not particularly costly.
    Get a 3 meter piece or so (if you can buy as little as that) and you will
    have enough to allow for eventual mistakes.
    The length will be corrected to the actual need when you tie the knots
    at the spring and cut off the excess length.
  • 01-20-2011 3:48 PM In reply to
    • Dillen
    • Posts 5,008
  • 01-21-2011 6:19 AM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    Durban South Africa
