I have a 4002 on a wall bracket, with a satellite box hung underneath, this is an adaptation to facillitate the shelf.
Thje waal bracket has 2 slots on the horizontal support plate, these are used with an MX top hung shelf, the holes on the wall bracket will need elongating, cannot remember whether outwards or inwards.
Eventually the shelf will hang there however the rear will need packing to establish a horizontal plane for the shelf.
I have pics somewhere, if you give your email by pm i will sort them out and forward them.
Do a search on flash your kit(?) one of my sets of pics shows the setup, think its about page 11
salut
Tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
