Latest post 01-18-2011 3:10 AM by fishta. 1 replies.
Page 1 of 1 (2 items)
  • 01-17-2011 10:06 PM
    • MESM
    • Not Ranked
    • Joined on 07-26-2008
    • Posts 15
    • Gold Member
    Center channel with Beolink passive
    Is it possible to use a Beolink passive to drive the center channel from a BS3?
    If this usage is possible:
    - The connection from BS3 to the Beolink Passive should be only by Powerlink? No use for the MasterLink?
    - How to drive/connect to the speaker? Beolink Passive drives left and right speakers, how to drive only one?
    (I am considering a passive non BO center speaker - a Bose one - a temporary solution before a full fledge B&O solution.)
    Regards,
    MESM
  • 01-18-2011 3:10 AM In reply to
    • fishta
    • Not Ranked
    • Joined on 02-12-2009
    • London
    • Posts 79
    Re: Center channel with Beolink passive
    You do not need to use a Passive kit at all. A much cheaper solution is to use something like a Parasound Z Amp which can be set to stereo or bridged mono for a centre channel. All you need is a Powerlink to Phono cable which your dealer or someone like Steve @ Sounds Heavenly can make . I have recently used these for a couple of BeoSound 5 installs where ceiling speakers were being used and used 3 on a BeoSystem 3 where the setup had Bose in wall and ceiling speakers for the 5.1 setup.
    BeoVision 7-40 MkV
