Vienna:
Time delay is necessary for all video sources to get "Lip-Sync" to the picture - audio sources
don't need to be delayed.
Does that mean there will always be the delay when I try to play the TV/DVD/AppleTV in the main room and link room?
Vienna:
Option setting will "tell" the unit how to handle audio commands (like "Radio", "CD", ...)
and/or video commands (like "TV", "SAT/DTV", "V.AUX", ...)
Or do you mean that if I get the optioning correct the delay will be sorted out.
I have a huge MP3 archive on my PC and it plays through the AppleTV and the dealy is unacceptable if I want to listen to music through out the ground floor of the house.
Finally, I get the L-OPT "4" for the BeoLab 3500, but what about the BV5 and BS9000, should they all be OPT 4 too.
Thanks for you help and quick response.
Stoobie
