Latest post 01-15-2011 11:41 AM by Karla. 1 replies.
Page 1 of 1 (2 items)
  • 01-15-2011 7:09 AM
    LOST SAT SUDDENLY in Avant 32
    Need help because my avant 32 dvd lost SAT connection. I can´t find it ind the menu. The list over different SAT BOX is gone.??
  • 01-15-2011 11:41 AM In reply to
    • Karla
    • Top 500 Contributor
    • Joined on 08-19-2008
    • USA
    • Posts 81
    Re: LOST SAT SUDDENLY in Avant 32
    Using the Beo4, turn the Avant on and then press "menu" "menur" to see the set up menu. Go to #7 and press go for external sources and look at the SAT listing.
    Change the SAT listing to none, exit the menus and power down the AVANT for 15 minutes.
    Bring the Avant back up, go back to external sources, and change the SAT listing to the selection that you want.
    This has happened on my unit, but usually because someone has accidently fiddled with the set. (usually me)
