Latest post 01-12-2011 4:04 AM by Raeven. 5 replies.
Page 1 of 1 (6 items)
  • 01-10-2011 4:38 PM
    • SKApretto71
    • Not Ranked
    • Joined on 04-19-2007
    • Europe - Italy - Tuscany - Fucecchio
    • Posts 66
    BeoSystem 3 and non B&O screen
    Hi all,
    Any advice from the users about non B&O (possibili LCD) screens to connect with beoSystem 3 as the main screen?
    From B&O in my understanding only BV4 is available...
    Thanks all.
    Raffaele "SKApretto n.71" Sgherri
    I like Chrome and spread it!
  • 01-11-2011 2:57 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Willich, NRW, Germany
    • Posts 1,077
    Re: BeoSystem 3 and non B&O screen
    Panasonic Professional Displays.... (Plasma), this was used for BV4 from B&O as well.
    You can find a lot of details on this site.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 01-11-2011 4:49 PM In reply to
    • SKApretto71
    • Not Ranked
    • Posts 66
    Sounds great, thanks.
    Any advice for the central speaker? I have a BV3, actually, with 8000 and 4000 BL2.
  • 01-11-2011 6:02 PM In reply to
    I have a 42 inch  LG Plasma connected to the Beosystem 3.  The image is sublime but I cannot control it via Serial Port(LG has a serial port for control).
     Also, center speaker is BL4000, front BL5, back BL4000, Surround BL1
    regards
    all sold!
  • 01-11-2011 6:15 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    There is a company, I think they are called Madsystems. They can modify a Beolab3500 so it can be used a center speaker.
    CraigSmile
  • 01-12-2011 4:04 AM In reply to
    • Raeven
    • Not Ranked
    • Joined on 11-03-2007
    • Posts 7
    Hello, have also a BeoSystem 3 with a 60" Panasonic screen. Spend a lot of time to control the screen via an IR link. In order to switch of the screen together with the BeoSytem 3. Later I foundout that this screen will (depending on the settings) automaticly swith on or off depending on the input.
    All works very well, I am using the B&O central speaker this one is very good.
