Thanks Mika,
I've checked the signals on Pins 27 and 28 - a nice beep every second or so, so the control signals are there.
This machine was not in great shape when the customer delivered it, no sound, CD not working, etc, lots of rust on the underside.
I did a nice upgrade, all Elna and Nichicon Audio caps in the signal path, 11DQ10's and 31DQ10's on the PSU, new laser, calibration, etc.
I tapped the AC off the opamps before the preamp, and ran it into another preamp , to test - sounds good.
I'll order a new TDA7318 and see what happens, in the meantime, I've put in a DIP-28 socket to save extra work later.
Learn from the mistakes of others - you'll not live long enough to make them all yourself!
