Latest post 01-10-2011 6:45 AM by ajames. 8 replies.
Page 1 of 1 (9 items)
  • 01-08-2011 3:36 AM
    Sky+ install today
    Hi all,
      I am having sky+ fitted today! I have had the stb chip upgraded last year has anyone got a map of which button will do what on the beo4? Cheers Nick
  • 01-08-2011 3:54 AM In reply to
    Re: Sky+ install today
    The card I have is rubbish! Your dealer should be able to give you a bigger one but essentially GO and whatever you want will do most things. Go + Red records and GO + << or >> fast forwards and reverses. Sky + integrates with my Avant brilliantly and also works in the link rooms fantastically. I am sure you will find it a very good addition.
  • 01-08-2011 4:36 AM In reply to
    Thank you for the response, if its not too much hassle would you be able to list the commands for me? Many thanks Nick
  • 01-08-2011 6:01 AM In reply to
    hi
    In search on this web page type in sky commands for beo4
    in there pdf file with picture of all commands which you can print off
    malcolm welborn
  • 01-08-2011 6:11 AM In reply to
    Thank you I did do a search but to no avail, now trying what you had put and all sorted! Thanks Nick
  • 01-08-2011 11:48 AM In reply to
    All working! I must say that sky is far superior to virgin media! Finished tidying the cables and fixing the box to the avant.
  • 01-08-2011 12:26 PM In reply to
    Re: Sky install today
    Just detach the lower rear part of the avant ( two or four plastic screws) and hide your decoder in there!
    Big empty space i used tonuse for decoder and lintronics device
  • 01-08-2011 12:52 PM In reply to
    yeah good idea, that would make it neat and tidy!
  • 01-10-2011 6:45 AM In reply to
    Never realised that that space was empty - is it ok then for the Sky+ to go there - not too much heat or anything? it would clear up so much space and less cables!
    Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
