Buying used B&O equipment:
First of all consider exactly what it is you want to buy, desided, do your home work, that means: f.exp. Beocenter 7000, in the search for this forum, search it, read which ongoing problems is normal for this equipment. Go to beocentral check what they got.
Second, if its posible, check the items before buying.
On auc.sites check prices over a month or so before starting bidding.
If you buy from an auc. site, check the availability, if you find  items corrosponding your wishes, check the fotos and descriptions, check the sellers rating, if you want to know more about it, ask questions, if needed ask for more pics. If the seller tells you that he does not know the equipment and cannot test for some reason or other, dont buy.
Nearly all BO more than 25 years old need new caps and lamps and a throughout cleaning, there is no way to avoid it.
Nearly all Beovox need new driver surrounds and all of then new caps.
All Beograms need a new cantilever ($ 150.00+) and new bands, the cantilever may work for a time, but sooner or later you will have to change, buy a new one from Soundsmith or get one repaired from Axel in Germany, but count that in when you buy a deck.
Last, check shipping fees, a lot of sellers makes a buck there too.
If you ever bought a used car and got screwed, you will know what to do
									    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
