1st March February 2012
Latest post 01-07-2011 5:03 AM by tournedos. 23 replies.
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Re: beomaster 7000 connect to beogram cd 7000
The CD won't need audio input lines, so even the 7-pin connector will
have two pins unused. Therefore the cable only needs five wires
(ground, L out, R out, data, and data ground). If you take a closer look, you should find that the non-connected pins are 1 & 4, not 6 & 7.
So unless somebody
has been in there rewiring the plug for some unknown reason, your
problem should still be sorted after just installing the missing two
pins. The problem is where to find them - I don't know if the dealers
have them anymore, but it won't hurt to ask. You can actually omit data
ground, so one pin should be enough.
If everything else fails, 7-pin 270° DIN plugs (with all pins fixed) are nothing special and
easily available, so you could replace the entire plug. I agree these
CDs are really annoying to use without working remote control!
wigwam
- Joined on 01-03-2011
- Posts 18
Thanks for your reply mika helpfull info so could i just take a pin from an old din plug and put it in to the hole?? would this work? becuase at the moment when i connect the din plug to the cd input in the beomaster the sound is realy low and i mean really low i have to connect via line out socket.. thanks again
tournedos
- Finland
- Posts 5,808
The original pins have a thread. If you try to stick something else
in there it won't stay. Try to get hold of the original detachable pins
or replace the plug.
Sounds like you're also missing the dummy plug from the line
in/out socket... without it, the preamp and poweramp of the Beomaster
aren't connected together at all, thus no sound except for some
crosstalk. You need to bridge pin 1->3 and 4->5 in that socket.
The
original dummy plug is a white plastic thing with these connections.
It's easy to build one from a spare 5-pin plug, but in a pinch a couple
of paperclips will do - I don't recommend it though as the socket may get damaged mechanically.
Doctor
- Joined on 09-14-2010
- Posts 555
You only need one extra pin - I can never remember which one!
wigwam
- Posts 18
hiya thanks again think iam going to have to solder a new din plug on, do you know the wiring diagrams for the pins currently it has 2-ground 5-black 3- yellow 1- white 4-red. are these correct and can i use these for the new din iam going to solder on.
Thanks again
tournedos
- Finland
- Posts 5,808
If you really have only those five wires in the cable and they really
have been connected like that, the cable cannot be original or somebody
has rewired it. In that case the colours can be anything.
Since
you get sound out, 2, 3 and 5 are correct, but I'm afraid the only way
to trace the data wires is to open the CD deck and see where they go.
The Beomaster CD socket uses pin 7 for data and 6 goes nowhere. 6 & 7 are connected together at the CD (I was wrong earlier when I said one of them is for data ground).
wigwam
- Posts 18
ok thanks i guess ill have to open the cd and trace the wires as yes i only have those 5 wires in the cable.. ill investigate further
wigwam
- Posts 18
ok just to clarify and make sense of this wiring on the din..... you need Ground. R/output. L/output. which is fine, but i still have 2 wires left are these data send and data recieve? and what pin or pins do they go to? or both wired to pin 7.
Thanks again.
tournedos
- Finland
- Posts 5,808
There is only one data signal. On the Beomaster, it goes to pin 7.
On the CD end, you need to connect it to whereever the pins 6 and 7 of
the original cable used to be... I can't remember how it looked, but
hopefully it is rather obvious; the PCB might even have the solder
points for a DIN socket although one is not installed.
EDIT: but by all means connect the signal to both 6 & 7 on the Beomaster end, so the wiring will be just like original.
Those two "extra" wires might be the original 6 and 7, and somebody has only rewired the plug for some odd reason. Could have even been a stupid attempt to compensate for the missing in/out dummy plug at the Beomaster - did you buy these at the same time in this condition?
wigwam
- Posts 18
yeah thanks for all your help its been very usefull,,, but iam still stuck on what colour wires go to what pins in the din plug. I have searched for a diagram but cant find one anywhere. All i know is ground is the wire that is sleeveless and goes to pin 2, as for the other 4 wires i cant make out what colour is R/out and L/out, and i will have 2 wires left over which i do not know which pins they go to.
wigwam
- Posts 18
hey sorry forget that last post, ive found a diagram that shows what colours to what pins. PIN 1 = YELLOW=OUTPUT LEFT PIN 2=SHIELD =SIGNAL GROUND
PIN 3=BLUE=INPUT LEFT PIN 4=RED=OUTPUT RIGHT
PIN 5=GREEN=INPUT RIGHT PIN 6=BLACK=DATA GROUND
PIN 7=WHITE=DATALINK
tournedos
- Finland
- Posts 5,808
Please disregard the colours. There is no standard for that, and the diagram you have quoted above doesn't even match the wires that are now correct in your plug (ground, L and R - pins 2, 3 and 5 respectively - must be right since you apparently got sound out of the CD).
I still suspect somebody has messed with the wiring before, as pins 1 and 4 are not connected to anything in a correctly wired Beogram CD plug. There is NO OTHER WAY to be sure where these wires go than to open the CD and take a look. If you feel you're not up to that, take the CD deck to somebody who can install a correctly wired 7-pin DIN cable for you.
Having said that, I believe those two extra wires should go to the data pins and some confused person has moved them to 1 and 4, but, see above...
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
To add to the confusion, the pins in the DIN socket are not numbered from one end to the other. F.e. pin 2 is the center pin of the seven. I may be able to supply a correct pin or two to screw in to the original plug (if it's still on the cable).
A photo or two of what you have, would help us help you.
tournedos
- Finland
- Posts 5,808
Oh yes, definitely be careful with the numbering of the pins. Most
DIN sockets and plugs have the numbers printed beside the pins.
As
I had some cleaning work to do, I took a couple of reference pics of my
BG CD6500 (should be internally the same as your 7000). The original
cable is colour coded like this:
2 ground
5 red (right)
3 white (left)
7 blue (datalink)
...so forget about the colours in your cable,
they will not match anything, but 2, 5 and 3 should be already correct. That
leaves the Datalink connection to be found & fixed, and it's
unfortunately a little bit more work than I anticipated from memory.
The instructions for opening the CD lid should actually be printed on the underside of the deck, do that first. The DIN cable is attached on the component side of the top circuit
board. You will need a Torx T10 driver to remove the screws around the board perimeter - except the two that are conveniently marked with "DO NOT LOOSEN". The screws are of differing lengths and with different washers, note which one goes where. Then the board hinges up and locks as shown.
tournedos
- Finland
- Posts 5,808
And here is a closeup of the area in question, with the thick DIN cable coming up from the bottom of the pic. It is connected to a 5-pin connection header, contacts from left to right:
- left out (white) - ground - ground - not connected - right out (red)
...and the wire going to the top right corner (blue in this case) is the Datalink signal wire that should be connected to pin 7 in the DIN plug.
This is what you should somehow manage to accomplish. The Beogram CD is a delicate machine - be very careful inside it, and if you feel at all unsure, have someone more experienced do this for you.
Hope this helps
wigwam
- Posts 18
Thanks , most helpful. The photos really give me some idea of how the layout is, and as you say if i can locate the data link cable inside the cd then that should solve the problem of the colour for pin 7. So the ground is fine and left and right output also, including the data link wire that makes 4 wires. i guess the 5th wire is terminated and goes nowhere as you refered to before. Thanks these forums really are valuble.
wigwam
- Posts 18
Think ive solved the mystery, and you were entirely correct after lifting the pcb board and investigating, the original b&o din cable has been cut and joined to another cable for some reason by the previous owner. the layout is the same as yours coming from the pcb board , white, black, black ,red and the blue data link which has been terminated in electrical tape. They are joined as follows to the other cable red-red, white-white, black-black, yellow-yellow. the yellow i guess is one of the black grounds. but why does the colour change.? Anyway the blue data link is just terminated. added some pics to explain better.
tournedos
- Finland
- Posts 5,808
OK, that makes sort of sense... the original cable was probably cut / damaged for whatever reason, and somebody has done a quick fix without much understanding.
Leave the audio wires alone as they are now correct, and replace the plug with a 7-pin (or use the one you have now, if you can locate a spare pin for it). Then use one of the unnecessary wires (to pin 1 or 4 now) to route the blue wire from the CD to pin 7, then you should be sorted
The cable split looks like a horrible mess, but never mind if it works. Make sure to insulate the connections so they can't short to anything on the circuit board.
tournedos
- Finland
- Posts 5,808
You have apparently shorted the Datalink wire to one of the audio signals. Go back and do it properly.
wigwam
- Posts 18
Ok Finally! all wired correctly and working well. At last! Thanks again. Been a real help. Any suggestions on some B&O speakers that work well with this system?
Thanks.
tournedos
- Finland
- Posts 5,808
Great! Wasn't such a simple job you expected
A Beomaster
7000 is convenient in that you can use any B&O speakers you wish,
from the vintage passives to the latest Powerlink-equipped active
speakers.
Recommending any single model usually results in an
argument... I have passive Pentas with my 6500 system, and I'm quite
happy with them. Something like RL60.2 would be good as well for a
completely different look. From even older speakers, S45-2 are lovely.
Some active speakers with displays would of course be nice - Pentas were often sold with these when new.
Page 1 of 1 (24 items)
