hi guys
how can i tell if my Beosound 4 has DAB? its on a stand so i dont want to dismantle it, and my invoice from B&O gives me no indication. There are about 30 preset radio channels, if that helps......................
Thanks guys
Kevin
Hi Kevin
If you PM me your serial number, I can check the type number of yoru unit which will indicate whether or not yor have the DAB tuner fitted.
Regards
Opman
done :-)
