Latest post 01-04-2011 2:33 PM by lausvi. 6 replies.
Page 1 of 1 (7 items)
  • 01-03-2011 6:27 AM
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Access Sources from Remote
    Dear all, I have two questions: 1. How do I access V.Aux from Beolink 1000? 2. How do I access the DAB Radio from Beo4 (on BS4)? Many thanks in advance for any feedback. Best regards Spiros
    Best regards
    Spiros
  • 01-03-2011 6:53 AM In reply to
    • kurfuer
    • Not Ranked
    • Joined on 04-22-2007
    • Dresden
    • Posts 35
    Re: Access Sources from Remote
    1) SHIFT+TV = V.AUX
    2) don't know for shure, but my understanding is, the sender list is mixed with FM radio, so access is RADIO
    regards
  • 01-03-2011 7:09 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Many thanks for the fast reply!!
    Best regards
    Spiros
  • 01-03-2011 12:16 PM In reply to
    • Karla
    • Top 500 Contributor
    • Joined on 08-19-2008
    • USA
    • Posts 81
    kurfuer:
    1) SHIFT+TV = V.AUX
    regards
    You have me confused on SHIFT+TV in that none of my three remotes has a SHIFT button. If you could advise or clarify it would be of a great help. Thanks.
  • 01-04-2011 3:00 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Fourth row from the top, in the middle....
    Sure you have a Beolink 1000?
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 01-04-2011 12:22 PM In reply to
    • Karla
    • USA
    • Posts 81
    kallasr:
    Ralf
    Wow! Thanks for the information. I was referencing a Beo4 from the orginal post, so it looks like I confused the issue. Thank again for this posting.
  • 01-04-2011 2:33 PM In reply to
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    With Beo4 you need to add SHIFT (or V.AUX) command to your LIST.
    We have all seen BL1000s with missing keys, but it took me weeks to notice that one of my BL1000s (got it with a BM4500) had two RESET keys! V.TAPE key was lost so the original owner had repaired it with "just some key" from another BL. I noted nothing wrong at first... Laughing
    Bang & Olufsen - The art of controlling sound, picture and light
