        1st March February 2012
	    Latest post 01-09-2011 8:47 AM by  Vienna. 21 replies.
									        Puncher
								                - Joined on 03-27-2007
								                - Nr. Durham, NE England.
								                - Posts 9,588
										    Speak to your dealer would be my recommendation!
Only then would I consider things like thinners, glass polish or Automotive polish, jewellers rouge etc.
Be very careful, you could end up with marks on the actual glass!
									        Vienna
								                - Joined on 08-15-2008
								                - make an educated guess
								                - Posts 712
										      Puncher:
... agree completely!
You'll also have to remove the speaker fabric, the aluminium frame, protect
the speakers & electronics from liquids and, and ...
Not an easy DIY job, IMHO - contact a qualified dealer/service first ...
									        Nickyg63
								                - Joined on 08-28-2007
								                - Nottingham
								                - Posts 628
										      Vienna:
  Puncher:
To be honest i think i agree, your dealer will try to sell you a new glass. No point spoiling a great tv!
									        bsantini
								                - Joined on 08-31-2008
								                - Seaford, NY
								                - Posts 162
										    AR is one thing I'm familiar with. Glass cleaner should NEVER be used with an AR surface, unless it is SPECIFICALLY formulated for use with AR (AR strips under both deviations from neutral with Ph).
That said, the companies B&O are having do their AR are under a price target.  Really good, long-lasting AR, with a hydrophobic and antistatic property for the surface area of a 42+ inch TV set is not gonna come cheap.  Maybe that's a contributor to the problems you're seeing.  I think it may be also why B&O made it optional on the smaller BV-10s.
FWIW
B
									        Vienna
								                - Posts 712
										      Emil:  ... but if I recall correct the price for a replacement glass will not be much less than a new second hand BV5 ...
650 - 700 EUR (including VAT) for an AR coated frontglass BV4/5-42"  + labour costs
									        Bentleyman
								                - Joined on 12-29-2008
								                - Rochdale
								                - Posts 367
										    Ok, AR = Anti-Reflective coating....?
I got a (2003) BV-5 and dont believe I got any problem with it - but then again I dont know what the symptoms of AR 'coming off' actually are....?
What are these symptoms you guys are talking about here?
Thanks,
									    Michael
BV5, BV Avant, MX4000, MX1500
BS 7000, BS 5500
Penta III, Penta II, BL 4000, RL 60.2,  RL 35, CX-100 Alu
BL 7000, MCP6500, MCP5500,  BL 5000,  Beo4 (x2), BL 1000 (x2)
									        Large48
								                - Joined on 06-24-2008
								                - London
								                - Posts 455
										    You notice 'holes' in the balck on the front of the screen, even though the glass is fine.
It's happening in a couple of places on my BV7 Mark 3...... :-(
									    Train Hard - Run Fast - Hit to Kill!!!
									        Puncher
								                - Posts 9,588
										      Bentleyman:
Thanks,
It will appear as if there as "smears" on the glass where the coating is missing, particularly visible when the TV is turned off. It comes about by over zealous cleaning using either materials or fluids unsuitable for the task.
It's very common on computer monitors (including CRT models) that have an AR coating, when people use screen cleaning fluids or solvents not designed for the task. LCD monitors are particularly problematic as the surface may not be glass and so can be more easily marked or damaged during cleaning.
									        Bentleyman
								                - Rochdale
								                - Posts 367
										      Large48:
I see. Assume you mean when the TV is 'Off'.....?
Well, cannot see this issue on mine fortunately, but what are the possible causes of this?
Wiping / cleaning too much? Applying too much pressure when cleaning screen? Presumably this AR coating wouldn't just 'fall off' on it's own, would it?
Taking the question to an extreme, say u had a screen which had never been wiped or cleaned in any way.....would the coating therefore be unaffected? I.e. Is it best not to ever clean ur screen!!?
									    Michael
BS 7000, BS 5500
									        Bentleyman
								                - Rochdale
								                - Posts 367
										      Puncher:
Ahhh...thanks Puncher, you beat me to it - my previous post to this was asking the sort of thing you have just answered.
So this 'smearing' effect of which you speak is only really noticable when the TV is off? Is it ever noticable when the screen is in use..? That presumably would become much more of an issue.
I've not noticed any smearing on my screen to be honest, but I shall now have a closer look out of interest. Even if there are smears on my screen though, I'm not planning on sitting scrutinizing the TV too much while its 'off' in any case
Thanks for your help
									    Michael
BS 7000, BS 5500
									        Puncher
								                - Posts 9,588
										      Bentleyman:
  Puncher:
It's certaining easier to see when off, if you catch the light the right way, if you know what I mean. It will be noticeable when the TV is on, in that it will no longer be anti-reflective, compared to the surrounding area and so may be apparent during certain scenes and certain ambient light conditions.
My advice to you would be.............don't look!  If you've never noticed a problem carry on as normal. If you specifically look for it and find anything you'll notice it forever! (Just like the annoying DIY error/bodge that nobody ever notices but you know is there)!
									        Bentleyman
								                - Rochdale
								                - Posts 367
										      Puncher:
My advice to you would be.............don't look!  If you've never noticed a problem carry on as normal. If you specifically look for it and find anything you'll notice it forever! (Just like the annoying DIY error/bodge that nobady ever noticed but you know is there)!
    HaHaHa....that is spot on! I shouldn't look in the first place now I know what to look for!
									    Michael
BS 7000, BS 5500
									        Vienna
								                - Posts 712
										      bsantini:
Absolutely right!
 You can easily damage an AR-Coating of screens, camera lenses, eyeglasses, ...
either mechanically, by scratching (or even abrasion by the wrong cleaning tissue)
or chemically, by using an agressive fluid.
E.g. in "User Guide BeoVision 7 - Getting Started" B&O recommends:
- Set up your television (EU page 23 / US page 21)
- Cleaning:
Maintenance:                 Regular maintenance, such as cleaning, is the responsibility of the user.
Screen:
                          Use a mild window cleaning fluid and lightly clean the screen
 without
                                       leaving streaks or traces. Some micro-fibre cloths may harm the optical
                                       coating due to their strong abrasive effect
Cabinet and controls :   Wipe dust off the surfaces using a dry, soft cloth. To remove stains or dirt,
                                      use a soft, damp cloth and a solution of water and mild detergent, such as
                                      washing-up liquid.
Never alcohol:
               Never use alcohol or other solvents to clean any parts of the TV
									        Emil
								                - Joined on 05-18-2007
								                - Stockholm, Sweden
								                - Posts 98
 Might have expressed myself incorrect but what my
dealer mentioned was that he had used a window cleaning fluid to remove the AR
coating in cases there this had already been damaged, i.e. definitely nothing
to use just in order to keep the screen clean. That being said, I own both a
BV5 and a 7-32 and has noticed that a mild window cleaning fluid
is ok with the 7-32 while the BV5 user guide state says that no liquid
cleaners should be used. Just out of curiosity - what is the difference between
the two coatings?
As regards the cost for a replacement front glass the price mentioned by
Vienna was actually a bit lower than I remembered I was offered three years ago
when I first time noticed this issue.
									        Vienna
								                - Posts 712
										      Emil:
...mentioned by Vienna was actually a bit lower than I remembered I was offered three years ago ...
650 - 700 EUR (retail including VAT) is just for the sparepart (in Europe) - NO LABOUR included in that price...
									        Russ
								                - Joined on 05-07-2007
								                - Washington, DC  USA
								                - Posts 641
										    As a matter of course, I have looked into this a little bit....  It seems that the glass panel on the BV-5 is not available as a separate part.  No real surprise I suppose.  So, in real terms you would order part # 3451777 currently selling for approximately $2000USD and receive an entirely new Plasma monitor.  A bit stiff to be sure, but you're not just buying the glass.  Worth considering.  Naturally, you can always just peel the AR off.
									    We kid because we love.
Bang & Olufsen Tysons Galleria
McLean, VA  USA
									        Vienna
								                - Posts 712
										      Russ:
I seriously doubt it'll be like that!
3451777 = Contrast Screen Plasma upd 2 (US Version) 3451454 = Frontglass Plasma / Contrast Screen BVi 4-42 & 5-42 (EU Version)
  As far as I know, #3451777 is just the front glass (wo plasma panel) and it retails for  approx double the price, compared to the EU version.
  approx EUR 1400 / USD 2000 will be the price for the 42" Contrast Screen - US Version approx EUR   700 / USD 1000 will be the price for the 42" Contrast Screen - EU Version
        Page 1 of 1 (22 items)
