Latest post 02-14-2011 4:43 PM by slowpat. 4 replies.
Page 1 of 1 (5 items)
  • 01-02-2011 2:37 PM
    • DerekM
    • Not Ranked
    • Joined on 01-02-2011
    • Posts 2
    Beogram 4002 not lowering arm completely
    I have a Beogram 4002 which has been out-of-use for a while.  I have recently tried to put it back in-service.  The pick-up arm attempts to lower, but only goes about half-way to the record.  Can I fix this myself?
    Derek
  • 01-02-2011 2:54 PM In reply to
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    Re: Beogram 4002 not lowering arm completely
    Hi Derek and welcome to Beoworld!
    I did it on my Beogram 4000 and 4002, which were completely stuck.
    Basically, you have to remove the lid, then open the deck (see here), remove the arm cap and unscrew the left part (two screws), which bears the arm lift along with the detector arm. Be careful, the wires are kind of fragile!
    Then you need to remove the circlip (you'll need a special tool, not expensive), pull out the moving arm (careful, it's hard and can come out all of a sudden, plus there's a spring which always wants to jump somewhere and live its own life... never to be seen again!), clean everything and put the thing back into place after a drop of fresh oil!
    Do the same thing with the horizontal lever, at the base of the arm (circlip, etc.).
    Not for the faint-hearted but provided you can handle mechanics I'm sure it'll be fine. Make sure you re-align the detector arm correctly.
    Good luck!
    Jacques
  • 01-02-2011 3:02 PM In reply to
    • DerekM
    • Not Ranked
    • Posts 2
    Thank you Chartz - I'll give it a try.
    Derek
  • 01-02-2011 3:04 PM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    You're welcome. Do keep us informed please!
    And the name's JacquesSmile
    Jacques
  • 02-14-2011 4:43 PM In reply to
    • slowpat
    • Not Ranked
    • Joined on 02-14-2011
    • California USA
    • Posts 7
    I just picked up a 4002 where the arm does not lower at all.  I followed the steps in the write up from CondorAudio, by lubricating the solenoid, lever, and the damper shaft, and now it lowers correctly.  The paper is a pdf file and available when you google it.  Let me know how it goes....
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
