Latest post 01-18-2011 9:57 AM by Stoobietoo. 2 replies.
Page 1 of 1 (3 items)
  • 01-02-2011 10:36 AM
    Beocom 6000
    I was tempted by these badly listed Beocom 6000 phones (6 total) but decided to leave them in the end.
    Sold for £279. I had emailed the seller who said they were 4 years old, but I couldn't reconcile that with the paint spattered appearance and the two differently shaped pyramid bases.
    Hopefully someone got a bargain rather than a set of well worn paint damaged incompatible phones!
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 01-02-2011 11:57 AM In reply to
    Re: Beocom 6000
    Probably older than 4 years as they are version 1.  Bases look compatible though - 1st is the controller base, 2nd is wall-mounted charger, 3rd is table-top charger.
    Juan Herrero
  • 01-18-2011 9:57 AM In reply to
    Re: Beocom 6000
    juanherrero:
    Juan is correct, I have a near identical setup. Mine is MkI version and must be just over 10 years old as they were bought when they first came out in 1999 (since had updated software to run a Beocom2). The silver pyramid base is the Phone base unit, and I have the same wall charger and 2 further black table chargers. (+Beocom2 & charger base) and all handsets compatible with each other and fit each base. (except Beocom2 naturally).
    Stoobie
