I have a question about BeoLab.
First,I would like to provide conditions for the issue .
I currently have a BeoVision 7-55 with 7-4 as center speaker and the BeoLab 5 as frontspeakers. As rear speakers, I have BeoLab 4000.
My question is when I run 5.1 sound from eg DVD / Bluray. When you have BeoLab 5 (and no subwoofer) you can not change the volume of the subwoofer channel, ie, .1-sound, because all the sound, including subwoofer sound, goes directly into the BeoLab 5. To be able to change the volume-level in the subwoofer channel, it is necessary of course to have a separate subwoofer.
Now to my question:
Can I change the settings of the TV so the settings is as if I had a subwoofer (Beolab 2) and connect additional Powerlink cables from the subwoofer output from TV to the respective BeoLab 5? . There are two PowerLink inputs to the Beolab 5-speakers. Next question? Will it affect the overall sound negative in any way to feed the Beolab 5:s with sound from two powerlink-cables for each speaker at the same time?
By connecting a subwoofer-cable to the each BeoLab 5, and change the setting on the TV to have the subwoofer connected, then I can change the volume of the subwoofer channel.
Please, does someone who has Beolab 5 in a surroundsound-setup thought of this problem with the subwoofer-channel (.1-channel)?
I hope you understand what my "problem" is and what I am suggesting to do in order to solve the problem.
Regards
Beolab 5 with sw 3.0, BV7-55 3D without Bluray(MK II), Beolab 7-4, Beolab 4000 MKII, Beolab 3500, Beovox CX100, Beosound 9000 mkIII, Cabinett 2054, Beo4 MKII, Oppo BDP-93 Blurayplayer (B&O-version)
