McRib:
I have an extra Beo4 and Beolink 1000 and both get leaking batteries on a regular basis, usually after a couple years. I only use the highest quality batteries but they leak anyway. On the Beo4, its the bottom battery that leaks, on the BL1000, it's the center battery. Any way to prevent this? Is there a rule of thumb for this, like if the remote won't be used for X months, take out the batteries?
Yup, there's a rule of thumb. Of sorts. If you have your battery operated things lying unsused for "a longer period", remove the batteries.
Personally, I'd even take them out if the item wasnt' used for a single month. Especially if the batteries weren't completely fresh and unused (i.e. if they are low on voltage).
Edit: Btw, I use Eneloop batteries in all my things these days. They're socalled "hybrid" batteries and other companies sell them under other names Eneloop is Panasonic's marketing name). They're rechargeable, but has very low self-discharge unlike normal rechargeable batteries, so they can be used for remotes and small pocket radios etc. They seem to have less tendency to leak, unlike alkaline batteries.
Perhaps that might be a solution to try?
