Latest post 12-31-2010 7:00 AM by scanorama99. 4 replies.
Page 1 of 1 (5 items)
  • 12-30-2010 2:12 PM
    Stb-controller for Motorola 1910
    Could someone please direct me to where on this site I can find info about stb-controller chips (I have silver membership).
    I would like to know if the chip for beosystem-1 that holds codes for Motorola 1920 also has got 1910 on the same chip or if they are on different chip versions...
  • 12-30-2010 5:35 PM In reply to
    • lano
    • Not Ranked
    • Joined on 04-25-2010
    • Posts 66
    • Gold Member
    Re: Stb-controller for Motorola 1910
    Hi, you can find it here: http://forum.beoworld.org/groups/stb-c_supported_products/forum/p/30538/263165.aspx#263165
    Motorola VIP 1910-9 is included in version 4.2 and 4.22 (which I belive is the latest one). Motorola VIP 1920 is included in version 4.00. I don't have any information regarding version 4.1 but it's the only version where both 1920 and 1910 might be included.
  • 12-30-2010 8:39 PM In reply to
    ok thanks!
  • 12-31-2010 4:34 AM In reply to
    • lano
    • Not Ranked
    • Posts 66
    • Gold Member
    On the other hand, have you tried using 1910-9 settings on a 1920. Often it works fine, it 's just some functipn that might not be availible.
  • 12-31-2010 7:00 AM In reply to
    I thought so also, I have no experience other than that I tried different sagem list-items forcontrollers for my current old Sagem-box that I had in a drawer but none of the names in the list worked. I will check with the chip I already ordered anyway.
