Latest post 12-30-2010 2:07 AM by Beobuddy. 10 replies.
Page 1 of 1 (11 items)
  • 12-28-2010 1:47 PM
    How do you turn on component cable hook up on Beovision 6-26
    So, I was gifted a Blu ray player and tried hooking it up to the tv.  I couldn't fiqure out what I need to do to the tv or remote to see the picture?
    Any thoughts?
    Guy
  • 12-28-2010 2:58 PM In reply to
    Re: How do you turn on component cable hook up on Beovision 6-26
    Doesn't your BV6-26 have a DVI input?
    If so, a HDMI-DVI cable will do the job.
  • 12-28-2010 4:35 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Beobuddy:
    ... if you prefer silent films Whistle
  • 12-28-2010 5:04 PM In reply to
    Right...that's what I thought.  So I guess the other alternative is the component plus audio plugs that are in the back.  Any other ideas?
    Guy
  • 12-29-2010 3:36 AM In reply to
    Vienna:
    Just try the Camcorder input.
    It senses probably video on the DVI connector when not on the videocomposite (camcorder-video).
    Quote from the manual:
    PC INPUT    DVI-D connector/audio L-R in 0,2-2V RMS >= 10Kohms
  • 12-29-2010 5:11 AM In reply to
    • Vienna
    • Posts 712
    Beobuddy:
    ... if TV is HD-Ready!
    Also the Y-Pb-Pr component (3x RCA/phono) are not active before HD ready update!
    Without HD-Ready upgrade of your 6-26 you can only use a SCART or the yellow "Composite"
    RCA of your Camera input + L/R audio in SD
    An upgrade with HD-Ready-Kit will be necessary to implement HDCP and enabling
    the DVI input to handle other sources than (not HDCP-protected) PC signals.
    The 4 digit Type # of your TV tells if it's a Mk1 or Mk2 version of the BV 6-26.
    (You'll find it by removing the speaker cover)
  • 12-29-2010 10:31 AM In reply to
    This is what I've tried up to now, thanks to your suggestions.  I pulled the computer DVI cable out and tried the component cables, didn't work.  I believe it is a mark 2 version because of the component inputs.
    The Blu-ray player works just fine when hooked up with composite cables, but I'm guessing I'm not getting the better resoulution that Blu-ray has to offer.
    I am going out today and picking up a HDMI to DVI connector that I will try using with two audio rca.  This is so frustrating, why make a great tv with great resoulution specs, but no way to attain them?
    I'm also wondering if a scart to component (with audio)exists?  Would it work with it?  I once bought one for my MX 7000 (scart to composite) and it just didn't work.  I'm wondering if B&O uses non standard pin locations in the scarts?
    Guy
  • 12-29-2010 1:12 PM In reply to
    • Vienna
    • Posts 712
    beoguy:
    BV6-26 has been introduced 2nd half of 2004!
    2004 only PC graphics delivered real HD pictures, a DVI-I input for PC use was the right choice those days!
    Connect your computer via DVI<>DVI od DVI<>VGA cable and enjoy your pictures ...
    SORRY, but HDCP is MANDATORY for reproducing copy protected HD content from sources like
    BD, HD-SAT receiver, HD-CABLE receiver, APPLE-TV, TViX, Playstation ...
    You'll have to upgrade your TV (HD-Ready-Kit) if you want to use either
    - COMPONENT 3x RCA-Phono for video + 2x RCA for audio or
    - DVI for video + 2x RCA for audio
    This is ABSOLUTELY NO DIY JOB and will require some SW updates too!
    - contact your B&O dealer and the B&O Service Center.
    PS: I've already mentioned this in my previous post -
          the Y-Pb-Pr COMPONENT (3x RCA/phono) will NOT be ACTIVE without HD ready update!
  • 12-29-2010 4:05 PM In reply to
    Smile
    I have just called the tech guy and left a message.  The fellow that answered the phone wasn't sure if the module would still be available!  Wow technology sure does move fast!
    Thanks for walking me thru this.
    Guy
  • 12-29-2010 6:41 PM In reply to
    • Vienna
    • Posts 712
    HD-ready-kit type 4371 can be used for BV6-26 Mk 1+2 and should still be available.
    (a friend of mine had his 6-26 upgraded a few month ago and the kit had to be ordered)
  • 12-30-2010 2:07 AM In reply to
    So finally, video over DVI and sound through RCA on the Cam works, with the minor detail of having a hd-ready kit Whistle
    Vienna:
    You seem to know it.
    So next question: What happens if you DO have a copy write protected BR disk/contents?
    Do you think you still have the full resolution on the component leads?
