Hi.
Second mail and already a question.
Some days ago I bought a CD 5500 via ebay.
First functionality check of the instrument was promising: CD tray went OUT and IN without any noise. Then I connected it to a BeoSound Ouverture via 7-pole-DIN-cable. Worked just fine. CD played and the Beogram CD could be contolled via the Beo 4 terminal and the Ouverture.
Then I decided to disconnect the player again and to clean the top of the player from some dust / grease – not taking note of the CD-tray moving out while I tilted the player to the front.
The CD tray touched the floor…
So after cleaning the outside I connected the Beogram again and ….but now every time the tray comes out during CD-loading I hear a deep “klonk” just after the CD-tray is moved about 2cm out.
When the CD is loaded and the tray moves in, no noise can be heard. CD can be played without any problem.
I am a bit nervous that I did some de-adjustment during the cleaning procedure while the CD-tray moved out and touched the floor.
I removed the cover of the Beogram CD and took a closer look. When the CD-tray moves from the play-position out to the load-position the following seems to happen: the CD tray moves about 2cm forwards. The supporting frame of the CD-mechanism (the frame which is fixed on the chassis of the Beogram CD by 4 levers) then “falls down” and touches the chassis of the Beogram CD resulting in the above “klonk”.
Does anybody know what to do?
Readjusting the height of the CD-mechanism relative to the frame around the mechanism by the 4 adjustment screws does not seem to help. (I tested and just hope that I got the same position of the screws afterwards as before).
Lubrification of the guide for the steel pin of the CD-tray with some "heavy" silicone grease probably is not the solution either?
Is there any damping material between the chassis of the Beogram CD and the supporting frame of the CD-mechanism, which can be hardened and broken?
Maybe somebody has got an idea, what to do?
Thanks and best regards
Frank
