Bentleyman:
Bentleyman:
Apologies, my pictures are of ludicrous proportions - I dont know how to resize them!
Can anyone tell me how to resize pictures posted in here, so that they are the correct size for the page..?
Thanks.
In this case when you are using the 'insert/edit image' function (I think?), you could just fill in the new h x v sizes in the 'dimensions' box.
However, this won't cut down a bit the amount of data a viewer needs to download to see them, so they will remain just as slow to load. The preferred way would be to use pictures that have been scaled down beforehand in some image processing app. If you keep the horizontal size to 700 pixels or so, that highly annoying horizontal scroll bar won't be needed (and won't appear).
Now matter how many megagigapixels a digital camera might have, the images will usually only benefit from scaling down by 1:2 - 1:4 or so...
That was a great looking setup in any case, so thanks for posting
