Yes to the first and no to the second.
Yes, you need the correct fuses and no, nothing else will be recommended.
You should be able to find some at almost any electronic parts store (or Ebay),
I may also be able to supply them if everything else fails.
Try locally first, that will save you the postage.
I would also recommend a quick check inside with a multimeter to see that
nothing else got damaged.
You already found this out, Ross, but for other Beoworld visitors, I would like to make it very clear
that adjusting the mains voltage setting switch should be done ONLY with mains disconnected.
Depending on model and version, f.e. going from the 220V setting to the 240v setting
sometimes involves passing the 110V setting which will most definitely kill something in the set.
Check fuses, transformer, rectifier(s) etc.
