hi,
these last two posts are great !
drdimitris, can you give me more information about your installation. i'm looking to find out just how waterproof the ir eye can be. does yours get rained on at all, for example ?
mine would be outside under a 'half-roof' (slats that cut direct sunlight, would not necessarily stop rain). can the ir eye afford a little rain ?
which brings me to molotow's comment. a laquer or varnish would certainly give more protection. do you have any idea what type was used ? has anyone else out there heard of such a thing ?
thanks again beoworld, the best source of information,
scott
