Latest post 12-29-2010 5:16 AM by Steven_London. 2 replies.
Page 1 of 1 (3 items)
  • 12-23-2010 4:30 PM
    Hoping some kind person will help with Pronto to Beo5 codes
    I was hoping that some kind person could help me out... I love my new BV7 but my dealer couldn't get my old Sony RDR-HXD710 DVD/HDD recorder to work with any of the existing PUC libraries and therefore the machine is sitting rather ideal at the moment. I did some research and I think that the Beo5 could be used to control the Sony directly.
    After doing some digging I managed to find a Philips Pronto command set which gives me the HEX? codes for the device (I have no idea if they work because I dont own a Pronto) but I know that in the past Keith has been able to create a Beo5 XML file from the Pronto codes.
    The codes to be converted are below (I did notice that the numeric keys seem to have a different format to then, not sure if this is a problem with the file I found on the internet).
    Power
    0000 0067 0000 0015 0060 0019 0030 0019
    0019 0019 0030 0019 0019 0019 0030 0019
    0019 0019 0019 0019 0019 0019 0030 0019
    0019 0019 0030 0019 0030 0019 0019 0019
    0030 0019 0019 0019 0030 0019 0030 0019
    0030 0019 0030 0019 0030 01C2
    Eject
    0000 0067 0000 0015 0060 0018 0018 0018
    0030 0018 0030 0018 0018 0018 0030 0018
    0018 0018 0018 0018 0018 0018 0030 0018
    0018 0018 0030 0018 0030 0018 0018 0018
    0030 0018 0018 0018 0030 0018 0030 0018
    0030 0018 0030 0018 0030 01C2
    HDD
    0030 0018 0030 0018 0030 0018 0018 0018
    0030 0018 0018 0018 0018 0018 0030 0018
    0018 0018 0030 0018 0030 0018 0030 0018
    0030 0018 0018 0018 0030 0018 0018 0018
    0018 0018 0018 0018 0018 01EF
    DVD
    0000 0067 0000 0015 0060 0018 0030 0018
    0018 0018 0018 0018 0018 01D9
    1
    0000 0074 0030 0000 0060 001F 0010 0010
    0010 0010 0010 0020 0010 0020 0020 0010
    0010 0010 0010 0010 0010 0010 0010 0010
    0010 0010 0010 0010 0010 0010 0020 0010
    0010 0020 0010 0010 0010 0010 0010 0010
    0010 0010 0020 1050 0060 001F 0010 0010
    0010 0010 0020 001F
    2
    0000 0074 0018 0000 0060 001F 0010 0010
    0020 0020 0010 001F
    3
    0020 0010 0010 1050 0060 001F 0010 0010
    0020 0010 0010 001F
    4
    0010 0010 0010 0010 0010 0010 0020 0020
    0010 0010 0010 1050 0060 001F 0010 0010
    0010 0010 0010 001F
    5
    0000 0074 002E 0000 0060 001F 0010 0010
    0020 1050 0060 001F 0010 0010 0010 0010
    0010 0020 0010 0020 0020 0010 0010 0010
    0010 0010 0010 0010 0020 0010 0010 0020
    0010 0010 0010 0010 0020 0020 0020 001F
    6
    0010 0020 0010 001F
    7
    0010 0010 0010 001F
    8
    0010 0010 0010 0010 0020 0020 0010 0010
    0010 0010 0010 001F
    9
    0010 0010 0020 0020 0010 0010 0020 001F
    0
    0000 0074 0019 0000 0060 001F 0010 0010
    0010 0010 0010 0010 0010 001F
    Prog+
    0000 0066 0000 0015 0061 0019 0030 0019
    0030 0019 0019 0019 0019 0019 0030 0019
    0030 0019 0030 0019 0030 01C7
    Prog-
    0000 0067 0000 0015 0060 0019 0019 0019
    0030 0019 0030 0019 0030 01D9
    Timer
    0018 0018 0018 0018 0018 0206
    Red
    0000 0066 0000 0015 0061 0018 0030 0018
    0030 0018 0030 0018 0018 0018 0018 0018
    0018 0018 0018 0018 0018 01DE
    Green
    0000 0066 0000 0015 0061 0018 0018 0018
    0018 0018 0018 0018 0030 0018 0018 0018
    0018 0018 0018 0018 0018 020B
    Yellow
    Blue
    0018 0018 0018 0018 0018 01F5
    System Menu
    0018 0018 0030 0018 0018 0018 0030 0018
    0030 0018 0030 0018 0030 01AC
    Title List
    0018 0018 0018 0018 0018 0249
    Guide
    Up
    0000 005B 0001 0015 001D 001F 0018 003A
    0018 003A 0018 003A 0018 003A 0018 001F
    0018 003A 0018 001F 0018 003A 0018 003A
    0018 001F 0018 003A 0018 001F 0018 003A
    0018 003A 0018 003A 0018 003A 0018 003A
    01CD 0071 0018 003A 0018 001F 0018 001A
    Down
    0000 0066 0000 0015 0061 0019 0019 0019
    0030 0019 0030 0019 0019 0019 0030 0019
    0030 0019 0030 0019 0030 019A
    Left
    0030 0019 0030 0019 0030 0183
    Right
    0019 0019 0030 0019 0030 0019 0030 0019
    0030 0019 0030 0019 0030 0195
    Enter
    0030 0019 0019 0019 0030 0019 0019 0019
    Return
    0030 0019 0030 0019 0030 0019 0019 0019
    Info
    Tools
    Play
    0000 0067 0000 0015 0030 0018 0017 0018
    0030 0018 0030 0018 0030 01C2 0060 0018
    0018 0018 0030 0018 0018 0018 0018 0018
    0030 0018 0018 0018 0030 0017
    Pause
    0019 0019 0019 0019 0030 0019 0030 0019
    0030 0019 0030 0019 0030 01AC
    Stop
    Fast Forward
    Rewind
    0030 0019 0030 0019 0030 01DE
    Record
    Record Pause
    0030 0019 0030 0019 0030 0019 0030 0019
    Record Stop
    Record Mode
    I really hope someone can help..... After the XML file has been created, is this something that my dealer is likely to want to add to the Beo5 because I dont have either the software or the XML files created by the dealer.
    Many Thanks
    Steven
  • 12-24-2010 12:08 PM In reply to
    Re: Hoping some kind person will help with Pronto to Beo5 codes
    Steven,
    I have converted the Pronto codes into a fully functional XML file for DIRECT control with the hardkeys pre-assigned.
    As you said the digits are different and decode to a carrier frequency of 36 Khz using the Philips RC6 protocol. I have included them just in case this product uses mixed protocols which actually seems fairly unlikely.
    Also, the UP command decoded to having a carrier frequency of 46 Khz which I think means it was not captured correctly.
    You can download the ZIP file containing the XML file HERE.
    If you provide your dealer with the ZIP file and he unzip's it on the PC with the Configuration tool installed and extracts it to C:\ then the XML file will automatically be added to the correct directory within the Tool.
    As I have pre-assigned the hard keys and digits all the dealer has to do is "Drag-N-Drop" into your configuration and download to your Beo5.
    Regards Keith....
  • 12-29-2010 5:16 AM In reply to
    Thanks very much Keith.
