The motor floor stand stand of Beovision 7-32 (6-26) is used for the BeoVision 10-40 (10-46) adding only the bracket adapter number 3130494?
Hopefully you can just replace the aluminum pole with the parts for the series 10?
Can you tell me if the two motor turntable unit are identical?
Thank you.
Andrea
