Latest post 01-05-2011 4:55 PM by Alias. 5 replies.
Page 1 of 1 (6 items)
  • 12-21-2010 12:55 PM
    ConfigTools for Beo6 ?
    Since Beo6 has come, is there also a new config Tools to program beo6 with?
    If soo, that is the name of the new CT-program ?
    My Bang & Olufsen....
    • BeoCenter 2 DAB/DVD mk.II
    • BeoVision 7-40 DVD mk.III
    • BeoLab Penta mk.III
    • BeoLab 4000 icepower
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beo 4 mk.I & mk.III
    • Beocom 6000
    • A8 Earphones
    Filed under: ,
  • 12-24-2010 12:43 PM In reply to
    Re: ConfigTools for Beo6 ?
    The Dealers have been provided with a new version which is used for both the Beo5 & Beo6.
    Regards Keith....
  • 12-26-2010 12:04 PM In reply to
    • YannChris
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Larmor-Plage, France
    • Posts 276
    Hello Keith,
    Does this version correct the battery-drain bug which appeared for several Beo5 owners with version 3.87?
    Kind regards,
    Yann.
    Ne pas s'en faire et boire frais!
    Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
    Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
  • 12-27-2010 4:23 AM In reply to
    Yann,
    I have not yet established if this issue is solved with the new firmware.
    However, I can confirm that there is a new firmware version (Beo5 Software) 1.45a
    Regards Keith....
  • 12-27-2010 5:26 AM In reply to
    • YannChris
    • Posts 276
    Thank you, Keith!
  • 01-05-2011 4:55 PM In reply to
    • Alias
    • Top 500 Contributor
    • Joined on 04-23-2008
    • Posts 90
    The new version is 4.11
