You can actually test that it is the cartridge quite easily. First try it as B&O intended. One channel will not work. Then take it out and turn it upside down and put it in. You will need to turn the gram on and once it drops, catch it and touch the stylus with your finger, The opposite channel will now not work and you will have tested the leads.
