Latest post 12-20-2010 7:04 PM by Seanie_230. 3 replies.
Page 1 of 1 (4 items)
  • 12-20-2010 9:47 AM
    Sky HD and Magic Eye
    Hi all,
    Until last week i had a Beovision Avant (in the lounge) and beovision 3 (in the bedroom). I have replaced the lounge avant with Panasonic panel (3D with internet tv etc etc). These and my beaosound 9000 were connected by masterlink
    I now have a tvlink.co.uk magic eye for my Sky HD transmission to my bedroom Beovision 3 however, I am unsure of the connections of this as it is not working. I have changed the settings on the sky box as required... not sure which input to use or even which remote? the Sky one or the B&O (i still have the IR cable that was used for using my B&O remote on my avant
    any advice is really appreciated...
    thanks in advance
  • 12-20-2010 9:57 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: Sky HD and Magic Eye
    When your Sky box was connected to the Avant, you were using the Set Top Box controller (STBc) within the Avant to control the Sky box via the infra red emitter. Now that you have removed the Avant, controlling the Sky box with the Beo4 isn't possible.
    Are you planning to leave the Sky+HD box connected to the new Panasonic screen? If so have you considered a multi room installation and installing the old Sky box directly to the BeoVision3 in the bedroom? You could then make use of the STBc within the BeoVision3 and could control that locally with your Beo4 remote control.
    Opman
  • 12-20-2010 10:16 AM In reply to
    Hello and Thanks Opman,
    Yes I have connected my Sky box to the panasonic screen
    I was not thinking of the multiroom installation, as there are only 3 of us and my daughter is only 4.. hence we have never needed to watch different channels at the same time, as this is the main advantage of multiroom
  • 12-20-2010 7:04 PM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Lintrocic -238 could convert the commands from beo4 to sky hd
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
