Latest post 01-08-2011 6:26 PM by Leslie. 3 replies.
Page 1 of 1 (4 items)
  • 12-19-2010 9:20 AM
    Missing parts BC9000 glasspanel plastic frames
    Try my luck again! Searching.....
    Display panel, middel section, lower part
    Touch panel, middle section, upper part
    Touch panel, right part.
    Gave the last part away to a Beoworld member and now you will see I need one for myselfSad
    Please PM if you have these for sale (or free)!
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 12-19-2010 6:55 PM In reply to
    Re: Missing parts BC9000 glasspanel plastic frames
    I think I have a spare upper centre section (aren't they the same) for the bottom (touch?) panel for the BC. Is that what you are after?
    Cheers
    Train Hard - Run Fast - Hit to Kill!!!
  • 12-20-2010 4:24 PM In reply to
    Maybe this picture makes clear what I'm missing.
    Just discovered that both frames I'm missing are the same.
    Can you PM me for the costs? Thanks, Leslie
  • 01-08-2011 6:26 PM In reply to
    Finally got them for freeSmile
