Latest post 12-19-2010 5:08 AM by bayerische. 19 replies.
Page 1 of 1 (20 items)
  • 12-18-2010 5:41 AM
    Beolab 5 problems with digital signal
    Hi guys,
    I was finally able to move back into our apartment yesterday! Very happy about that, been "homeless" since august first!
    Anyway, connected all bits last night, and I'm having a problem with my beolab 5's...
    The system now consists of BV10, BS9000 and Beolab 5.
    It's connected as follows:
    BV10 -> BS9000 with ML
    BV10 -> Beolab5 with Powerlink
    BS9000 -> Beolab5 with digital coaxial
    The problem I'm having is that the Beolab 5's seem not to get/ignore the digital signal... It's a long time since I last pulled the digital cable out from the speakers while playing music, but as I remembered there was a short pause, now I can't hear anything.
    The reason why I got into testing this is that I first had them connected like this:
    Mac Mini -> Beolab5 with digital coaxial
    And couldn't get any sound from the Mac Mini.
    Now is my problem as simple as a cable fault? (I don't have a meter, but can buy one) I have switched over the digital cables, but it did not help, hard to believe both to be broken, but then again I can imagine the Beolab 5's will only work if both digital bales (loop) are properly fastened.
    What should the cable values be if I go out and buy a meter?
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 12-18-2010 6:17 AM In reply to
    Re: Beolab 5 problems with digital signal
    I think you should check your option settings and what you have set up as audiomaster. For the s/pdif to be recognized by the speakers when you press CD, i think you need to check the config btw bs9000 and bv10.
    Others here will be more knowledgeable than me as to specifics.
  • 12-18-2010 6:39 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Digital in/out on BLb interchanged by mistake ?
    "Power reset" done ?
    After connecting and option programming of all components
    disconnecting of all units from power for approx 2 minutes is
    always recommended.
  • 12-18-2010 7:53 AM In reply to
    Thanks for your replies.
    The options should be, TV -2, Bs9000 -0.
    But should I set these manually, or?
    -Andreas
  • 12-18-2010 8:00 AM In reply to
    • Vienna
    • Posts 712
    Yes & Yes
  • 12-18-2010 9:42 AM In reply to
    Did the power reset, nothing changed, also checked manually (with Beolink 7000) that BS9000 is set to 0 and Beovision 10 is set to 2...
    Nothing changed...
    Is my problem related to me having the speakers connected to the TV? I had them connected to the TV before also, but I don't think I ever had them connected to the TV while using a mac mini as transporter...
    -Andreas
  • 12-18-2010 10:13 AM In reply to
    • Vienna
    • Posts 712
    are digital cables connecting BSd 9000 <> BLb5 <> BLb5 working when selecting CD ?
    mac mini connected to TV :
    AV input #?
    configured as ? e.g. "V.Mem", ...
    connected by HDMI ?
    or VGA or Component + SPDIF ?
  • 12-18-2010 10:28 AM In reply to
    bayerische:
    OK, did what I said, and it works now....
    So having the TV in option 2, and BS9000 in option 0 with powerlinks from TV to Beolab 5's seems to block the digital input...
    So what do I do now......? Will the speakers work with surround sound left/right via ML to the BS9000? I suspect not...
    Damit... Will my only option now, be A.aux and a good DA converter...?
    Or is there a way to open the above described problem, making the Beolab 5's accept spdif even if connected to the BV10?
    -Andreas
  • 12-18-2010 10:37 AM In reply to
    Vienna:
    AV input #?
    connected by HDMI ?
    I don't have the Mac Mini connected to the TV... Only connected to a separate Cinema Display in another room, only connection to the Speakers via spdif coaxial cable.
    So you think connecting the Mac mini via SPDIF to the TV instead of the beolab 5's would make it work, by making the macmini ie V.mem?
    -Andreas
  • 12-18-2010 10:45 AM In reply to
    • Russ
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    If you had everything connected as described, then you ought to be fine.  When the BeoLab 5's 'see' an audio source 'displayed' on the PL cable, they automatically check the S/P-DIF input first, and if a signal is present, they lock onto it and stay.  This is one major reason that you must use fully-mounted PL cables in these set-ups.  The data signal must be present.
    Since the mini is playing when it is connected to the 5's instead of the 9000, we can expect that the cables are OK.  Try this...reconnect all of the B&O gear as it should be (listed in the OP) play the CD and try to adjust bass or treble...if there is an audible change, then you do have a problem of some sort.  No change, no problem!
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 12-18-2010 10:57 AM In reply to
    Russ:
    Russ
    Russ, the spdif channel works just fine when I have tv in option1 and the bs9000 in option 1, with only ML running between BS9000 and BV10. Powerlinks connected to the BS9000.
    But would a better option be to connect a "v.mem" thingy with only the spdif, and set it with an spdif entry, should this give sound to the Beolab 5's via powerlinks connected to TV?
    Having the system set up in my original way:
    Did not make the Beolab 5's listen to the SPDIF even when I chose CD.
    -Andreas
  • 12-18-2010 11:17 AM In reply to
    • Vienna
    • Posts 712
    A/V setups - like the one you have - will:
    - send sound to the Speakers (center / front / rear / sub) from all sources through analog PL-cables exept *)
    - receive digital sound of sources connected either by HDMI or SPDIF (and, of course a video connection
      via DVI / VGA / SCART / COMPONENT) as there are only digital INPUTS (but no OUTPUTS) available on the TV.
    *) In your specific setup the digital input of the BLb5s can only be used for CD playback in stereo (speaker 2)
    ! If an other speaker setting is selected manually or by setup (e.g. Speaker 3 / 4 / 5 for audio sources)
      the system will use the ML connection instead of SPDIF and the sound will be processed by the DSS
      module and delivered by PL to the speakers - even if you select CD.
  • 12-18-2010 11:24 AM In reply to
    Well now I have it all working, with a small run around, making me able to save the spdif to the speakers from my CD.
    Connected the Mac Mini to DVD2 on the TV only by spdif. It works. The screen is lit, but black. Will muting the screen make it off? How to mute the screen with Beo5?
    -Andreas
  • 12-18-2010 12:35 PM In reply to
    • Odd88
    • Top 500 Contributor
    • Joined on 07-25-2010
    • Norway
    • Posts 86
    • Gold Member
    The beovision 10 don't have datalink in the powerlink outputs, the beolab 5 needs datalink too work with the s/p-dif.
    Blame google translate for my bad EnglishStick out tongue
    My Bang & Olufsen.
    • Beovision 8-40
    • Beosound 9000
    • Beolab: 5/3/2/8000
    • Beo 5 / Beo 4 / Beotime
    • Form 2 / A8 Earphones
  • 12-18-2010 12:58 PM In reply to
    Ok, do you guys think my setup will suffer poorer sound quality now? Is there anyway to get datalink or to trick the speakers into thinking datalink is there? Feel somewhat strange about feeding bl5 with ml...
    -Andreas
  • 12-18-2010 3:44 PM In reply to
    • Vienna
    • Posts 712
    bayerische:
    Edit of my previous post:
    CD Playback only - if an other speaker setting than Speaker 2 (Stereo) is selected manually or by setup
      (e.g. Speaker 3 / 4 / 5 for CD
      the system will use the ML connection between Audio and TV (instead of SPDIF directly to BLB5)
      the sound will be processed by the DSS module of your TV and delivered by PL to the speakers.
  • 12-18-2010 5:33 PM In reply to
    • Odd88
    • Norway
    • Posts 86
    • Gold Member
    I am happy with the sound from the 9000 in my set-up, but the sound with s/p-dif is a bitt better, I will upgrade to a beovision 7 to get datalink, when I find a used sett for a good price that is.
    My Bang & Olufsen.
    • Beovision 8-40
    • Beosound 9000
  • 12-18-2010 6:18 PM In reply to
    Vienna:
    bayerische:
    So if the speakers are set to "2", the previous system I described:
    Should work?
    -Andreas
  • 12-18-2010 8:45 PM In reply to
    • Vienna
    • Posts 712
    Sorry, my fault - have to edit my post a second time:
    ! CD Playback only - if an other speaker setting than Speaker 2 (Stereo) is selected manually or by setup
      (e.g. Speaker 3 / 4 / 5 for CD )
      the system will use the ML connection between Audio and TV (parallel to SPDIF directly to BLB5)
      the sound will be processed by the DSS module of your TV and delivered by PL to the Center and Surround
      speakers
    . This will cause a time delay between front BLb5s and the other speakers.
    Works on a BV7-40.
    Odd88:
    The beovision 10 don't have datalink in the powerlink outputs, the beobab 5 needs datalink too work with the s/p-dif.
    Odd 88 is right - if the BeoVision 10 does not transmit (display) data via PowerLink  - the BeoLab 5 will never
    receive the command "CD" and therefore never switch from PL to SPDIF.
    PS: PL cable must be a fully mounted one - a PL Mk3 won't work.
  • 12-19-2010 5:08 AM In reply to
    I'm using MK2 PL.
    -Andreas
