Latest post 01-03-2011 4:15 PM by stotty1111. 17 replies.
Page 1 of 1 (18 items)
  • 12-18-2010 3:39 AM
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    BS4 SD file types
    What file types can the BS4 now read?
  • 12-18-2010 8:33 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: BS4 SD file types
    MP3 & WMA.
    Up to 2gb SD/MMC card or if software is 2.15 or higher up to 8gb SD/MMC card.
    Opman
  • 12-18-2010 8:39 AM In reply to
    • symmes
    • Joined on 04-21-2007
    • Freedonia
    • Posts 290
    . According to the documentation, WMA files up to 192, MP3 files up to 320. If you rip MP3 files with LAME encoding, I find that is a very nice recording that will play anywhere. For years I have used CDEX, a free utility, then sucked them into iTunes for use with iDevices. I dont use iTunes for building SD cards, buts that's just me. Updated BS4 software allows 8G card. Not sure of spec.
  • 12-18-2010 12:36 PM In reply to
    • UK
    • Posts 970
    WMA, does anybody seriously use WMA?
  • 12-18-2010 12:50 PM In reply to
    B&O does Whistle
    The race for quality has no finish line- so technically, it's more like a death march.
  • 12-18-2010 6:13 PM In reply to
    • SWISS_2
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Opman;
    Per your post: How do you verify the software version on Beosound 4 ?
  • 12-18-2010 6:52 PM In reply to
    • Opman
    • Cheshire, UK
    • Posts 323
    BeoSound4 in Standby
    Press menu.
    Turn wheel to select "set up" & press go.
    Press 0 0 go.
    Turn wheel to navigate in the service menu.
    1 in service menu is software version.
    Opman
  • 12-18-2010 7:36 PM In reply to
    • SWISS_2
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Using the directions, I show number 1. as  AP 1.3.
    Is that correct  or is the OS ?
  • 12-19-2010 5:44 PM In reply to
    • Opman
    • Cheshire, UK
    • Posts 323
    The latest software for BeoSound4 is 2.15. This gives the new features as described in the supplemental instruction book that can be downloaded from the Bang & Olufsen website.
    Opman
  • 01-02-2011 1:45 PM In reply to
    • stotty1111
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    opman
    can you give a link to the supplemental instruction book please, i've looked but can only fins thethe original 32 page job - am interested to see the additions as my sw version is 2.01a
    salut et bonne annee a tous
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 01-02-2011 3:16 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Most of my digital music is in WMA format.Laughing
    CraigSmile
  • 01-02-2011 3:17 PM In reply to
    • Craig
    • Posts 4,855
    CraigSmile
  • 01-02-2011 4:08 PM In reply to
    • Teletom
    • Top 500 Contributor
    • Joined on 05-09-2007
    • the Netherlands
    • Posts 111
    • Gold Member
  • 01-02-2011 4:25 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Brilliant - thanks for that!
    Another question, with sw 2.01a is 2gb still the max size of sd card?
    tony
  • 01-02-2011 5:11 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    stotty1111:
    Bonne annee, Tony!
    For SW2.01 2Gb is the limit.
    Depending on the Ser.# of your BSd4 :
    An update requires either just a new SW via ServiceTool of your dealer/service
    or an additional change of EEPROM before updating the SW.
  • 01-03-2011 6:21 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    vienna
    ser no -- 20366671
    can you give an idea of cost for sw update in €
    salut
    tony
  • 01-03-2011 2:50 PM In reply to
    • Vienna
    • Posts 712
    Hi Tony
    Please check your current AP-SW-Version:
    Menu -> Setup… -> Options… press [0 + 0 + GO] -> SW versions…
    IF: AP-SW is 2.01 or higher
    THEN: only an update to AP 2.15 / Codec 04 version 1.31 will be necessary (via service tool)
    costs: approx 1/2 hour = +/- 40 EUR
    ELSE: first a HW-Upgrade (exchange) of the EEPROM (new EEPROM containing SW 32.15 or higher )
    followed by an update to Codec 04 version 1.31 will be necessary (via service tool)
    costs: approx 1,5 hours + EEPROM = +/- 140 EUR
  • 01-03-2011 4:15 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Vienna
    You're a gent sir!
    brilliant, sw version is 2.01a!
    Now to get the upgrade will apparently cost me more to drive the 300km roundtrip to Rennes than the actual cost of the upgrade - lifes sweet isn't it - hey ho!
    again thanks for your efforts!
    salut
    tony
