Latest post 12-15-2010 7:05 AM by davefarr. 3 replies.
Page 1 of 1 (4 items)
  • 12-15-2010 4:24 AM
    Foam Sticky Tape
    Does anyone know where I can get some double sided sticky foam tape suitable to reattach the touch sensitive glass panel on the front of my Beosound 4500? Thanks
  • 12-15-2010 4:59 AM In reply to
    Re: Foam Sticky Tape
    Yes here
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=170434514812&ssPageName=STRK:MEAFB:IT
    Regards Graham
  • 12-15-2010 5:38 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Just for future reference (ebay link will not be there forever....):
    Black double sided foam tape 6mm x 5mtr super strong - from ebay seller more-than-tape on www.ebay.co.uk
    I remember having seen this refered to as Bang & Olufsen... Beomaster... etc. tape, selling for a lot more...
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 12-15-2010 7:05 AM In reply to
    I've used the tape from More-than tape from eBay and it certainly is sticky stuff and seems to match the size I needed.  I'd use that for all my B&O tape required repairs.  I had a job getting the backing tape off though!.
    Dave.
    Am I ready? I was born ready!
