Latest post 12-14-2010 6:50 PM by Movie. 3 replies.
Page 1 of 1 (4 items)
  • 12-13-2010 4:08 AM
    • Movie
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Posts 90
    Apple TV and Remote
    Just got Apple tv installed, - the Beo5 will not turn it on,  is this normal.
    Should I leave it on all the time, or do I have to use the Apple remote to turn on and then use  Beo5 to control.
  • 12-13-2010 8:46 AM In reply to
    Re: Apple TV and Remote
    my experience is with the new apple TV and a Beo4.
    I had to unpair the apple TV from the remote that it was shipped with and which I had used to install and configure the apple TV.
    Once I had done that, the apple TV responded to the signals the PUC sent (that were triggered by the Beo4).
    Unpairing is a configuration option inside the menu of the extreme right hand side of the apple TV's main menu screen.
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 12-13-2010 9:34 AM In reply to
    • Movie
    • Posts 90
    Thanks elephant, will give  that a try.
  • 12-14-2010 6:50 PM In reply to
    • Movie
    • Posts 90
    That seems to have solved the problem, thanks Elephant.
