Latest post 12-12-2010 8:32 AM by Daniel. 6 replies.
Page 1 of 1 (7 items)
  • 12-11-2010 12:33 PM
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Shall I upgrade my BS9000?
    My BS9000 is going to service on Monday. When it plays CDs, the music is interrupted all the time with short breaks for a second or so.
    The question is, should I go for an upgrade to mk3 (from mk1)? I will soon connect a MacMini with all my music to the TV. Do I benefit with Nmusic and Nradio in the BeoSound then, or is it of no use for me? Any other advantage with Mk3?
  • 12-11-2010 2:29 PM In reply to
    Re: Shall I upgrade my BS9000?
    Your dealer will probably fit a new CD mech which will make it equivalent to the Mk3. Get  him to also upgrade the software to the latest spec and you will have a Mk3.
    Regards Graham
  • 12-11-2010 2:34 PM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    Is it costly with a software update?
  • 12-11-2010 5:39 PM In reply to
    The chip is only around £20!
    Regards Graham
  • 12-11-2010 6:14 PM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    Thanx, Graham!
    OK, then it will be a new chip.
    Any guess/info what a new CD mech will cost?
  • 12-12-2010 1:15 AM In reply to
    £150-£200 in the UK
    Regards Graham
  • 12-12-2010 8:32 AM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    Thank you! That's what I guessed.
