Latest post 12-13-2010 10:20 AM by tpwuk. 6 replies.
Page 1 of 1 (7 items)
  • 12-10-2010 6:11 PM
    • tpwuk
    • Not Ranked
    • Joined on 01-05-2009
    • Posts 15
    Problem with Century
    I've had my century for 17 years now and just now it's decided to act-up on me!
    The door opens and closes by itself, the radio will switch itself on & off, CD's will jump about from track to track, all quite random things really.
    Any ideas?
  • 12-10-2010 9:27 PM In reply to
    Re: Problem with Century
    have you added any new electrical appliances to the environment?
    microwave?
    plasma TV?
    DECT phone?
    etc
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 12-11-2010 4:13 AM In reply to
    • tpwuk
    • Not Ranked
    • Posts 15
    Thanks for the tip.  It could possibly be a wireless baby monitor or one of the IR sensors for my house alarm.
    Will start by moving the monitor to another room.
    Cheers,
    G
  • 12-11-2010 4:42 AM In reply to
    The IR thing sounds logically to me;
    I once had an IR remote for a lamp that used a close frequency to the century's door open IR logic.
    Activating it opened the door sometimes although there is no "official" BEOlink-command to open those remotely. It was definitely an interference.
    At least that's an explanation for the doors; not sure about the station switching; these are totally different frequencies...
    Good luck,
       Gunther
  • 12-12-2010 7:44 AM In reply to
    • tpwuk
    • Not Ranked
    • Posts 15
    I moved the Century into another room where nothing will interfere with it but the problem still occurs! :(
    I'm beginning to think something inside has failed.
    Does anyone know of a B&O repair specialist close to the Blackpool area?
    Thanks,
    G
  • 12-12-2010 8:20 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    If you are using the "Handle - FM antenna" unplug it.
    If using an antenna cable to receive FM via cable unplug the cable
    from the wall outlet as well as from your Century (both sides!).
    If the problem is caused by external units this may help to verify
    that problems are caused externally. If so, the source has to be found
    - otherwise servicing will be required.
  • 12-13-2010 10:20 AM In reply to
    • tpwuk
    • Not Ranked
    • Posts 15
    Thanks for the advice.  I have the "Handle Antenna" and will give that a try tonight.
    Cheers,
    G
