Latest post 12-13-2010 8:35 PM by Vienna. 4 replies.
Page 1 of 1 (5 items)
  • 12-10-2010 2:38 PM
    • fishta
    • Not Ranked
    • Joined on 02-12-2009
    • London
    • Posts 79
    BeoSound 5 and Slave Audio
    Hi Guys
    When setting up a BeoSound 5 as an audio master and having a BeoCenter 2 or BeoSound 4 as a slave what options do they need to be in and what do you need to tell them that they are slaves?
    BeoVision 7-40 MkV
  • 12-11-2010 8:41 AM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: BeoSound 5 and Slave Audio
    It depends on where they are placed! If in separate linked rooms they should be set in A.Option 5 (If TV is also there) or 6 (If all alone). For N.Music and N.Radio just add these commends on your Beo4 or Beo5 and that's it.
    Best regards
    Spiros
  • 12-12-2010 2:26 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    So, have you tried it already?
    Best regards
    Spiros
  • 12-13-2010 6:18 PM In reply to
    • fishta
    • Not Ranked
    • London
    • Posts 79
    There is no B&O TV in the room with the BeoSound 4 and I put in A.Opt 6 but if I choose n.music nothing happens. There are two link rooms with passive kits and if you select N.Music in them with the BeoSound 4 connected they turn on then off instantly. Without it connected it works perfectly. I haven't however tried selecting Cd in the link rooms though.
    It almost feels as if the BeoSound 4 doesn't want to be in option 6 eventhough it accepts the option by the led flashing.
    Any other clues??
    BeoVision 7-40 MkV
  • 12-13-2010 8:35 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    After changing components and/or (re)programming of options,
    it's always a good idea to disconnect all components from the mains
    for several minutes.
    After restoring power wait a minute and repeat option programming.
    Again disconnect all components from power and restore power after a
    minute.
    Wait a minute before starting the system.
    This procedure should release a system ...
