Latest post 12-15-2010 5:43 AM by kallasr. 15 replies.
Page 1 of 1 (16 items)
  • 12-10-2010 6:29 AM
    IR Transmitter/blaster for control of Sky+ HD box from an Avant.
    Hello, Just recently purchased my 32 DVD Avant type 8453 with STB-C  but I do not have the IR lead to control the Sky box from the Beo4! Can I use any readily available Blaster or transmitter or do I need the Specific Item from B&O. Also which B&O product code is it & how much. I desperately want to get this up & running
    Many thanks
    Filed under:
  • 12-10-2010 6:37 AM In reply to
    Re: IR Transmitter/blaster for control of Sky+ HD box from an Avant.
    I think they are standard - at least my one appears to be - just make sure you have the right size plug on the end - I think it's a mini jack. Cost should be around £10 - perhaps try maplin or a dealer?
    Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
  • 12-10-2010 9:05 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    It's a standard cable - 3,5mm mono jack.
    The "original" B&o IR-blaster cable has B&o item/order# 8330352 and retails for approx EUR 9 + VAT
  • 12-10-2010 9:51 AM In reply to
    Thanks I hope you are right I have just ordered this from amazon as Maplin didn't have what I wanted.
    Thanks again
    Marmitek IR Eye universal IR extender cable
  • 12-10-2010 9:52 AM In reply to
    Thanks my local B&O dealer quoted me £30 for this item, I have gone elsewhere
    Thanks again
  • 12-10-2010 1:22 PM In reply to
    • Vienna
    • Posts 712
    stote21:
    EUR 40 has been the price in 2008 - now it's one of the few B&O articles that got significantly cheaper ...   Smile
    Angry Your dealer should have had a look on recent prices ...
  • 12-10-2010 1:53 PM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    I did not know you can get them from amazon Can you post a link to the item so i can buy one for my new but old beivision 3
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 12-10-2010 3:34 PM In reply to
    Hi Seannie_230,
    I tried a few from different sources that didn't seem to work too well on my BV8-32 (or that didn't work at all).  Many of the ones advertised are actually IR receivers, not transmitters (often very badly described) as they are often intended for use with Media Centre PC's.
    In reply to your request for a link, I've found some good IR transmitters (which I use on my own TV) and I've made them available here: http://soundsheavenly.co.uk/bando-tvir.htm
    Hope this helps,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
  • 12-10-2010 3:59 PM In reply to
    Seannie_230 this is what I have ordered after reading about what it says its capable of, I will let you know if it works I am looking to control a sky +hd box and also a free view box on my 2003 Beovision Avant 32 DVD. After speaking with my local B&O dealer he thinks it should work
    http://www.amazon.co.uk/gp/product/B000MBY1FC/ref=olp_product_details?ie=UTF8&me=&seller=
  • 12-10-2010 5:11 PM In reply to
    I paid £15 for an official B&O IR blaster from a dealer: it comes with a very long length of cable. If you want to control two boxes (Sky and Freeview (probably an old Panasonic model if you don't want to pay for a later chip)) then you will need the B&O splitter (one gold connection, one silver) to enable the different signals to go to each relevant box. The splitter is not expensive.
    Search the forum for more on this topic.
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 12-10-2010 6:22 PM In reply to
    • kpcvlp
    • Not Ranked
    • Joined on 05-09-2007
    • Posts 6
    I got one from dealer, cost £11 including next day delivery
    Colin
  • 12-11-2010 8:49 AM In reply to
    Guys,
    This has been very interesting learning all this about the pricing from a dealer, I am now very disappointed with my quote from Lincoln B&O. If I had been quoted something like 10-15 pounds then I would of just bought it. Could you please direct me to a dealer that will provide for a reasonable cost just in case my 3rd party article does not work....I have my fingers seriously crossed now!
    Thanks again all
  • 12-11-2010 9:18 AM In reply to
    • Vienna
    • Posts 712
    As already mentioned, approx GBP 30 for the IR Blaster cable is an out-dated price from 2008.
    Simply ask your lokal dealer to check the current price for B&o item/order# 8330352 ...
  • 12-11-2010 1:54 PM In reply to
    • kpcvlp
    • Not Ranked
    • Posts 6
    I ordered my from b & o of Hampsted , I use a couple of dealers and Hampsted price,s always come out cheaper.
    for example I had a quote for a beolab 11 and hampsted was £200.00 cheaper, so it does make sense to call a couple of dealers.
    colin
  • 12-15-2010 4:55 AM In reply to
    To all that replied & gave me very good advice I thank you all again!
    UPDATE = The Universal IR Extender Cable Lead (2x Eyes) I purchased from Amazon on the earlier link (in this thread) from Keene Electronics does work on my Avant Big Smile
  • 12-15-2010 5:43 AM In reply to
    • kallasr
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Do both eyes work? E.g. do you control a STB AND a DVD etc.?
    Thanks!
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
