Latest post 12-15-2010 3:02 AM by Spiros. 16 replies.
Page 1 of 1 (17 items)
  • 12-09-2010 3:58 PM
    Marktplaats B&O set
    How much is this worth in good condition and if the BM6000 has failures can this be repaired?
    Seller is asking 275 euro's
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 12-09-2010 4:56 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: Marktplaats B&O set
    Much more!!!!!!! Take it!!!!!!!
    Best regards
    Spiros
  • 12-09-2010 9:10 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Enough that if you don't hurry up I might get a ferry over to Holland and grab that myself!!!
    Serious bargain you have got there!!!!
    Olly.
  • 12-10-2010 3:16 AM In reply to
    What a steal!
  • 12-10-2010 7:07 AM In reply to
    Guys,
    Need your help asap!
    Tomorrow (Saturday) I'm going to see this set and test it on functionallity but the owner does not have any batteries in the BM6000 remote. What kind of batteries does this remote needs so I can bring them with me.
    Fast repsonse  is much appreciated!
    Leslie
  • 12-10-2010 7:13 AM In reply to
    • Paul
    • Top 500 Contributor
    • Joined on 10-07-2010
    • The Netherlands
    • Posts 103
    • Gold Member
    Leslie it is a 15V Varta V74PX IEC 10 LR54  Conrad sells them. Good luck tomorrow :-)
  • 12-10-2010 11:45 AM In reply to
    Hi Paul,
    Thanks! You've been there. Let's see if my findings are the same as yours...
    Will let you know.
  • 12-11-2010 12:58 PM In reply to
    Step1:
    I saved you the trip! What a dissapointment this was. It looked horrible, the looks of the alum. fronts was almost brown. BM6000 and record player 4002 (I'm sure I thought I have read in the ad it was BG6000) were in full working condition. Some lights on the BM6000 were defect. Beocord was also okay. Speakers were also okay with some light marks and scuffs on the top. Remote looks ok but was not working! For someone who wants to do a project refurbishing this set it would be a challenge. I didn't want to do that...
    I cancelled the deal mainly because I thought the BG6000 was part of the set.
  • 12-11-2010 1:52 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    I am sorry it wasn't what you were looking for - amazing how pictures can disguise so much!!!
    I wonder if the 4002 had the CD4 decoder built in?
    Olly.
  • 12-11-2010 2:28 PM In reply to
    Step1:
    Sh.t, haven't checked that! Thought only the 6000 had quad.
  • 12-11-2010 4:47 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    They could be upgraded. If you check the cable it should be extremly thick there is also a switch in the side of the unit, however that is not a guarrentee that it has a demodulator board built in - I think you would have to remove the servo panel to be absolutely sure!
    Olly.
  • 12-12-2010 6:49 AM In reply to
    • Paul
    • The Netherlands
    • Posts 103
    • Gold Member
    Well the ad is removed from marktplaats. Did someone bought the set? I am curious who bought it, or the seller removed it and will put it on marktplaats again after some time
  • 12-12-2010 7:28 AM In reply to
    I have a 4002 without the decoder but with the thick cable and a switch on the side.
    It has a dummy decoder board!
    Regards Graham
  • 12-12-2010 8:33 AM In reply to
    • Paul
    • The Netherlands
    • Posts 103
    • Gold Member
    Just to learn something from you guys...:-) There are a few records that are recorded as Quadro. So to have a decoder in a beogram is nowadays for collection vallue?
  • 12-12-2010 8:42 AM In reply to
    Paul:
    There's not much use for it as a CD-4 decoder, if that's what you're after - not that many records exist, most people won't have the quad amp/speaker setup, you'll need an expensive new/renovated cartridge so that it'll actually play in quad, and finally the recordings aren't that groundbreaking anyway.
    The real value is that it functions as a RIAA preamp even in stereo, so the Beogram will have line level outputs and will plug straight into modern kit. And it's an excellent quality preamp as well (may need a recap at this time to live up to its own standards, though).
    -mika
  • 12-14-2010 4:05 PM In reply to
    Paul:
    On again!
  • 12-15-2010 3:02 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    And with a "better" price!!!!!!!!!!
    Best regards
    Spiros
