Dear all,
Sorry for what must be a very basic question. I have a beomaster 5500 that I would like to connect up to my two extra speaker kits. It seems from the MCL2 manual that I have two options:
1. Use one of the four 7 pin Din connections (most sensibly Aux) to connect to the MCL2
2. Wire up two proprietary (non-DIN standard) connectors from the speaker 2 connections to the MCL2
Unforutnately I am using all four 7 pin connectors for components, and I can't find the 3 pin connectors anywhere.
I was thinking I might be able to make use of the 6 pin DIN sensor connector somehow, but unfortunately I can't find pin out information for this connector anywhere. Does anyone know what the pin outs are for this, and if they meet the requirements of the MCL2 (signal left, ground left, signal right, ground right, DC supply, datalink, shield)? The sensor connector has 12V 10ma printed next to it - is this compatible with the MCL2 power requirements?
Many thanks for your advice, with best wishes
Luke
